  New Posts New Posts RSS Feed: drilling holes in floor
Topic Closeddrilling holes in floor - Event Date: 15 Jun 2014
Happy Tripping View Drop Down
Direct Link To This Post Calendar Event: drilling holes in floor
    Posted: 15 Jun 2014 at 12:19am
Hello.
I tried a 'search', no luck.
(I am NOT a skilled tool user.)
1. I want to put a bracket into the floor of the pass-thru for storing levelling boards. Drilled one hole, it seems VERY flimsy. Should I use glue, and if so, what is best one? Do #8 3/4 inch long screws hold in the floor?? Should I use these - 'Multi-Purpose Anchor Kit with Screws' or 'molly screws' (from previous post)?? Is there a better idea??
2. I'd like to add towel bar above radio on my 171 but would need to pull radio out partway to see inside above radio, but screws of radio are not phillips type. Is there a technical term for the radio's screw type? (I don't want to wreck the screws)
Thanks for your patience.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 15 Jun 2014 at 12:46am
The floor is a sandwich of plywood with an expanded polystyrene foam core (think old fashioned white Styrofoam cups). There is nothing in the floor for strength. The plywood is thin.
I know this because I drilled through with a half inch bit to mount a hanger, and abandoned the idea after seeing the foam spill out from underneath, I sealed it up with silicone.
Direct Link To This Post Posted: 15 Jun 2014 at 12:48am
Originally posted by Happy Tripping
Is there a technical term for the radio's screw type? (I don't want to wreck the screws)Thanks for your patience.
I think they are called Robertson Square drive. There are bits for the changeable tip type screwdrivers.
Direct Link To This Post Posted: 15 Jun 2014 at 6:12pm
Thanks a lot!
Anyone know if there is a particularly good glue for this purpose on this thin floor, one that is strong but 'removable'?
I don't like the thought of the leveling boards sliding around uncontrolled.
