Riser being installed - any considerations? |
Podsible Dream
podders Helping podders - pHp Joined: 03 Dec 2010 Location: Hightstown, NJ Online Status: Offline Posts: 571 |
Topic: Riser being installed - any considerations? Posted: 20 Dec 2013 at 9:28pm |
You might want to use some 4x4 blocks to raise the front ends of the dome long pole. That will raise the dome to a level condition. The side grey panels are a bit short but at learnt the dome is level.
Chris and Walt
'10 RP-171 'Free Spirit' '13 Dodge Durango Crew 5.7 L Hemi V8 |
GaRedneck81
Newbie Joined: 24 Jan 2013 Location: Kennesaw, Ga Online Status: Offline Posts: 22 |
Posted: 16 Dec 2013 at 10:24pm |
Your step will also be affected.
GaRedneck81
USN Retired RP-172 |
Itsgr8
Newbie Joined: 16 Oct 2013 Location: United States Online Status: Offline Posts: 5 |
Posted: 08 Dec 2013 at 8:20pm |
I had to lower my hitch before to accommodate the r-pod. I am sure that I will have to raise it if just a little.
2010 R-pod 173
2012 GMC Canyon |
Sleepless
Senior Member Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
Posted: 08 Dec 2013 at 6:08pm |
When I installed my risers, it raised the frame 4 inches. I had to raie my hitch 2 holes (4") to keep the pod level when hitched. You are right, if the trailer was not level to begin with.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
Posted: 08 Dec 2013 at 5:56pm |
... unless raising the pod leaves the tongue level or slightly nose-down (either is correct).
Sleepless
Posted: 08 Dec 2013 at 4:41pm |
You will have to raise your hitch ball to match the increased height of the pod coupler.
Itsgr8
Posted: 08 Dec 2013 at 4:03pm |
I bought a 2010 R173 a year ago. This month, I'm having the axle risers installed. I've read some of your posts and see that the Dome awning will be affected. Is there anything else? I want to make sure that I am prepared for the changes. Thanks in advance!!!
