Lefty
Calendar Event: Remove light bulbs Posted: 08 Sep 2013 at 2:24pm |
I've searched and can't find this. It must be simple but I'm having trouble removing the light bulb from the socket. I've pushed up on the little wedge and tried to pull the bulb out of the surrounding box but it won't pull out. Any suggestions?
David and Danette
Posted: 08 Sep 2013 at 2:52pm |
Which light bulbs are you trying to remove the interior or exterior. The interior lights I think they should slide out of the their sockets by pulling on them. If they are stuck you will need to be careful the bulb doesn't break but I think if you wiggle it, should slide out. Our pod is a 2009 the lights may have changed at some time with the newer pods. David
2014 Ram 1500 Quad cab
Sleepless
Posted: 08 Sep 2013 at 2:59pm |
Originally posted by David and Danette
Which light bulbs are you trying to remove the interior or exterior. The interior lights I think they should slide out of the their sockets by pulling on them. If they are stuck you will need to be careful the bulb doesn't break but I think if you wiggle it, should slide out. Our pod is a 2009 the lights may have changed at some time with the newer pods. David |
I believe all the pods still use the 921's like yours and mine use. When I replaced mine I had to wiggle them, as you suggested. Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
kymooses
Posted: 08 Sep 2013 at 6:34pm |
wiggle wiggle wiggle.
3 wiggles not 2 not 4!
LOL
janice
Posted: 15 Sep 2013 at 7:22pm |
Where might I find the 921 replacements in LEDs at a reasonable price?
marwayne
Posted: 15 Sep 2013 at 7:56pm |
All I can say , you get what you pay for. I paid 15$ a piece 3 years ago, have not had any problems.
Bill-GA
Posted: 15 Sep 2013 at 8:19pm |
I purchased these (from China) about a year ago, and haven't had any problems - been out about 8 weeks ... at $20+ for 10x units you cant beat the price. The large 12x LED is equivalent to the incandescent lamps IMO. The gap in the lamp allows for cooling. Don't get sticky pad version!
Here's a USA(?) version which I think might be better quality at a higher price ... Needs 921 adapters.
**** I just ordered qty 2 from lightmalls as backup .... It ships from CHINA.... Oh well.
Bill & Bev
13 yr old dachshund 'Elsa'
2011 Toyota Tundra 2WD TV
dsmiths
Posted: 15 Sep 2013 at 10:43pm |
Bill-Ga I got mine from china also and have 2.5 seasons on them with no problem, they are a little bluer than I care for but I only use them in the bunk areas, the bathroom , the exterior light and both lights over the dinette. I keep the center lights and over the stove incandescent as I think the light is a little brighter and needed for the work area.
Dane and Donna Smith
2011 RP-172
lift kit
