Originally posted by Craneman
I just finished installing my riser kits this morning,2 1/2 hrs tools put away and cleaned up. I`m kinda slow. the one thing i did that I haven`t heared any one talk about is making sure the axle get back to the same position for alignment purposes. I made a reference mark and used a square,it didn`t go back on it`s own. all in all it was a pretty easy job. Moe |
You did better than I did, Moe. I finally started this morning and did not even have the wheels off before my wife told me it was 79 degrees in the house. Had to stop, checked the heat pump and found the starting capacitor had blown. Simple replacement, but finding a replacement was difficult. Got the heat pump back into operation, had lunch and finished the riser installation. Total time was over 5 hours. When you live in Florida, women seem to think air conditioning is more important than working on a R-Pod.
By the way, my dealer had really torqued down the lug nuts. I used a pneumatic impact wrench and even with 150 psi pressure, they would not budge. Ended up using a 1/2" drive socket with an 18" socket bar, and finally slipped the handle of my floor jack over the bar. That did the trick. Lesson learned to to check your lug nuts before going on a trip. RV dealers, car and tire shops, etc., seem to have a tendency to over-torque lug nuts. Had I been away from home, I would not have been able to remove them if I had a flat.
Bob
