cdremy
Topic: Vent less gas fireplaces Posted: 26 Feb 2013 at 12:33pm |
Looking at buying a gas vent less fireplace for my basement. It appears they all come without a blower. They show this as a option you have to buy separate. Any recommendations on which fireplace to buy and is the optional blower needed to thoroughly heat the room.
tsunami123
Posted: 04 Mar 2013 at 11:34am |
 'Vent-less' means that combustion gases are 'vented' into the room. Supposedly, the exhaust gases are only water vapor and carbon dioxide. Carbon monoxide is always a possibility and the so-called 'oxygen depletion' shut-off switches are not perfect. Make sure that you have a window to vent both the moisture and CO2. I would also buy a backup Carbon Monoxide alarm for the room. A lot cheaper than a couple of funerals. Without a fan, the warm air from the fireplace will rise to the ceiling and stay there. A blower will help spread the warmth around the room.
CharlieM
Posted: 04 Mar 2013 at 11:39am |
VERY good comments and advice!
Thinker
Posted: 04 Mar 2013 at 4:57pm |
A friend that had one got rid of it because of the amount of moisture it dumped into the room. Would you consider a ceramic electric heater and fireplace DVD (just kiddin.. )
Keith-N-Dar
Posted: 04 Mar 2013 at 6:22pm |
I thought about this since it was first posted and decided not to be a downer. Now I have changed my mind. I would never put any unvented heater in my house. Even with detectors the risk is go great in my opinion. I remember the unvented heaters from my youth and even in an old drafty house the headaches we would get. It could have been much worse. Sorry to be a wet blanket. Do what you think is right. I did need to give my opinion.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted: 07 Mar 2013 at 8:21pm |
While I don't fear ventless, I wouldn't put one in a basement.. they give off a lot of water vapor, something most basements don't need. However, the "direct vent" appliances don't need a real chimney,they just need to reach the outside to draw/expel air.
P&M
Posted: 12 Mar 2013 at 7:49pm |
I'd suggest you try and see if you can go with a direct vent FP rather than a ventless ... as others have said it puts a ton of moisture into the room. My father-in-law found this out the hard way when he ended up with mold issues.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
cdremy
Posted: 15 Mar 2013 at 2:43pm |
Thanks for your replies. Think I'll look into the vented style.
