Generator when camping |
Post Reply | Page 12> |
Author | ||
dsmiths
Topic: Generator when camping Posted: 02 Mar 2013 at 7:32pm |
The Pod does have a carbon monoxide detector in it that should catch any problems. However I would not trust my life to a $30.00 detector. I would place the gen set away from the pod, aim the exhaust away from the pod.
Dane and Donna Smith
Keith-N-Dar
Posted: 01 Mar 2013 at 10:22pm | |
If you are running your generator to run the air in your Pof you won't hear the generator. Everyone without air in the campground will, but you won't.
Keith-N-Dar
tsunami123
Newbie Joined: 07 Dec 2012 Location: MINNESOTA Online Status: Offline Posts: 21 |
Posted: 01 Mar 2013 at 6:11pm | |
One problem with generator exhaust noise is that low frequency sounds can penetrate nearly any material while high pitched sounds are easily diminished by most materials. I was in one campground where a large RV was running its gen late at night. You could sit up in bed and the noise was not too bad...but as soon as I laid my head/ear on the mattress the low notes were impossible to sleep with.
Thinker
Senior Member Joined: 25 Feb 2013 Location: S. Mississippi Online Status: Offline Posts: 171 |
Posted: 01 Mar 2013 at 4:33pm | |
Good Point, I will remember that.
Tars Tarkas
Posted: 01 Mar 2013 at 2:10pm | |
Be extremely careful about running the generator under the camper. Carbon monoxide is nothing to fool around with. You might do fine, but if you don't you may never know.
TT
Thinker
Posted: 01 Mar 2013 at 12:43pm | |
I was afraid of any gasoline odor?? DW has a tender nose. Another thought is to put the cargo carrier on the roof of the TV and carry the auxilliary fuel tank up there... safari style..
Camper Bob
podders Helping podders - pHp Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
Posted: 01 Mar 2013 at 11:29am | |
When traveling, if you can't fit it into your tow vehicle, how about inside the Rpod on the floor inside the door. Does not increase the tongue weight an appreciable amount. When camping, put under the rpod near the front. Safe Travels.
Camper Bob and Camper Sue
Thinker
Posted: 01 Mar 2013 at 11:20am | |
Note, for comparison... Yamaha also has an Inverter... IT DOES NOT HAVE THE FUEL PUMP LIKE THE HONDA.
Thinker
Posted: 01 Mar 2013 at 11:19am | |
Now, I gotta figure out where to carry this Gen stuff. One idea is to put a Yakama cargo basket up top and move the spare tire there. I can then put a cargo tray in my rear receiver. I think it will handle it. My tongue weight will probably balance when I load some stuff in my forward dinette area.
Any ideas anyone?
Thinker
Posted: 01 Mar 2013 at 11:17am | |
Noise may depend on the type of generator. I have an old Generac that you could hear anywhere in the campground... stays in barn now.. Not allowed out.
I also have a pair of Hoda 2000 Inverters.. The main generator has 12v charging etc too, the Companion allows you to sync up both of them for a full 30amp power source. These little Hondas purr, noise is low. BUT the best thing is that they have a fuel pump. With a special cap http://www.amazon.com/EXTENDED-FUEL-HONDA-Eu2000i-GENERATOR/dp/B004BJ5YKM/ref=sr_1_1?ie=UTF8&qid=1362154440&sr=8-1&keywords=honda+generator+cap You can hook up an outboard motor fuel tank Mine runs for days on a single tank. Hose can be split with a T to run two generators on a single tank. Easily gives you all night AC ..... The generators sip fuel as the speed does not determine frequency. As inverters they are generating DC (no frequency_) then inverting it to pure sine wave AC. So when the load drops, the speed drops. |
