  New Posts New Posts RSS Feed: RP193 kitchen sink not running
Bonnieladd View Drop Down
Post Options Post Options   Quote Bonnieladd Quote  Post ReplyReply Direct Link To This Post Topic: RP193 kitchen sink not running
    Posted: 23 Sep 2023 at 3:00pm
My father is going to be staying in our r-pod 193 for a few days.  So, I hooked up power and the water hose to my fresh water intake so that he could run the air and have running water.  I turned on the water pump and ran the water for a few minutes to bleed the air out and thought everything was fine.  However, when he tried to use the sink later, no water came out.  The water is still turned on at the source and it is still flowing to the RV.  Water still flows in the shower and the toilet.  It's just the kitchen sink.
Any ideas?
2022 RPod193
Music City USA
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 5:08pm
Check the aerator on the faucet, sometimes they get clogged and the water wont flow. We clean ours a couple times a season.
Tars Tarkas View Drop Down
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 6:17pm
+1 to Leo.  If the water is running everywhere else, it's almost certainly just that the aerator is clogged.
TT
FJ Cruiser
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2023 at 12:08pm
+2 Your aerator is the likely culprit. If you haven't already, flush your hot tank when you get a chance. Just be careful to relive the pressure on it before you pull the anode rod.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Triumph T120
Post Options Post Options   Quote Bonnieladd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2023 at 2:31pm
That did the trick.  Thanks for helping out this newbie.  It's my first RV and we just got it this Spring.  So, everything is new to me.
2022 RPod193
Music City USA
