  New Posts New Posts RSS Feed: homemade awning
homemade awning
zzimmer3 View Drop Down
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Topic: homemade awning
    Posted: 19 Sep 2023 at 12:08pm
this is a crappy pic of my homemade awning. its a 10x10 tan tarp, with homemade 5/16" machine screws slid into the track.
poohbill View Drop Down
Post Options Post Options   Quote poohbill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 1:21pm
My attempts to use that track have been thwarted by the downspout interfering with the feed. Can you share your hardware design?
2016 179 Gastropod
2017 Ridgeline
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 2:18pm
i'm uploading it now, my phone is super slow. but it is a 5/16" machine screw, 2"s long, i clamped the head in a vise, put a washer and nut almost all the way down, then tapped the screw over almost to a 90 degree. the head slides in the channel.
Post Options Post Options   Quote poohbill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 3:38pm
Thanks! What do you use for the awning? A common tarp?
2016 179 Gastropod
2017 Ridgeline
lostagain View Drop Down
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 6:38pm
You may want to check a marine supply for sail slides that can fit into the track.  They come in various shapes and sizes for the track.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 6:53pm
I ordered a medium duty tan tarp from Amazon. It only had 4 grommets on each side, so I ordered a grommet kit and made 5. One completely centered and then two were it starts to curve. Then on the ends. I bought 8' telescoping poles too. I had to add a grommet on the center of the pole side, I extended the center pole 8: and the two corner poles about 7' or so. It seems pretty good.
Post Options Post Options   Quote poohbill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 8:11pm
We have a Pahaque cover for the slide because we camp in the trees so much, but one person on a teetering ladder is not sufficient for a load-and-pull install. You have to work it through. I've found it easier to simply sweep the top before retracting.
2016 179 Gastropod
2017 Ridgeline
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 9:47am
  I just bought one as well. Mine slides in really easy, i carry my little ladder with me, as long as the ground is ok i shouldn't fall off, i hope. it seems to work well and looks snazzy too. i like it.
Post Options Post Options   Quote zzimmer3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 9:50am
