  New Posts New Posts RSS Feed: Simple Green
Simple Green
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Topic: Simple Green
    Posted: 24 Apr 2023 at 6:27pm
   Does anyone have experience using Simple Green to clean their camper? A RV shop recommended it for cleaning our camper. I need to clean the roof haven't cleaned it in over a year and it's gotten very dirty. I want to give a good cleaning then inspect the sealent for any cracks and reseal if needed.
2014 Ram 1500 Quad cab
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2023 at 6:53pm
I have used the product in the past however since it has been a year and you state the "roof is very dirty" it would be prudent IMHO to be more agressive.  Most likely you will have some oxidation that has taken place over the year so a product like Meguiar's Oxidation Remover (blue bottle) will give you excellent results.  It is an oxidation remover as well as a heavy duty cleaner.  After that if you want to go all out, try using a clay bar over your rpod as well (skip this process on your decals) as it will remove any impurities on the surface and leave a 'baby butt smooth' finish when you are finished.  After that use the polish of your choice for the final product.
lostagain View Drop Down
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 5:55am
+1 to jato's recommendation of Meguiar's cleaning products.  They work very well.  If you don't want to use that brand, any marine supply house will have a large selection of other fiberglass/gelcoat cleaners that will also work well.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
hogone View Drop Down
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 7:50am
I just ordered a bottle of Meguiars Oxi Remover.  Never used it before but the old pod needs a cleaning.  So just squirt it on a rag/brush and scrub on correct; or any other tricks of the trade!!??  Jon
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 10:23am
   How about oil spots on the front of camper from I guess being behind large trucks that have oil coming from their engines? I agree I need something more aggresive than Simple Green I am 68 years old it's a lot of scrubbing I am getting wore out Ouch. I am using caution it's not the safest thing to do the fiberglass is slippery if the detergent isn't rinsed well. I think I will do what I can with the Simple Green then use something better like a Meguiars product.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 10:33am
When we used this on our 179, we tried it by hand first and didn't like the results. The surface showed swirl marks and was uneven. We re-applied a second time using a Harbor Freight buffer and it came out much more even. Finished off with Meguiars Mirror Glaze and the Rpod was shiner than it was new.
Do not apply the Oxi remover in direct sunlight and don't allow it dry. You should be good.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 1:06pm
+1  Sorry I didn't mention that in the above post although I believe that those instructions are included on the bottle: don't apply in direct sun.
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 2:17pm
   I finished cleaning the roof except for a few oil spots. Simple Green works OK I mixed another bottle making a stronger solution and that cleaned better. I bought at Lowes a gallon of concentrate Simple Green and it came with a spray bottle pre mixed which I think wasn't mixed very strong. I would buy it again but l would not recommend it for oil spots. When I am finished washing the entire camper I will wash it again with RV Wash and Wax that's something I recommend I have used that for years washing our campers, trucks and cars.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 5:52am
Those stubborn oil spots will come out with a clay bar.  Takes a little time but mixed with some patience you will have success.
