A couple questions about caulking |
mjlrpod ![]() Senior Member ![]() ![]() Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1221 |
![]() ![]() ![]() ![]() Posted: 02 Oct 2022 at 7:53am |
What type of caulking should be used for vertical (non roof) applications? If I do roof areas with self leveling, does all the old stuff need to come off, or can I can I just replace sections. And I bought some self leveling in caulking tubes, can I cover large areas by going back and forth with tube caulking, or do I need to get something like a pail of it that I can slather it over a larger seam. Thanks
2017.5 Rp-172
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
I used ProFlexRV. They sell a fast set as well as self leveling. I went with the fast set so that it would be workable on the vertical applications. Keep some mineral spirits on hand to clean up and tool the caulking. I did remove as much of the old caulking as I could. Used a basic scrapper multitool from Home Depot followed by a good wipe down with denatured alcohol. The ProFlexRV is high adhesion, so if you don't get everything off, it will still stick well. Good luck!
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
to add one more suggestion- make sure the scraper is plastic and not metal--not as much chance of scratching/cutting the underlying material. some caulks can be better removed if you moisten them first with mineral spirits/alcohol or your choice . Read the instructions. then scrape. Travel safe and often Vann
Thanks, Pod People. Softening the caulk is a great idea. Ours was softened up by Rapid Remover when we were removing our old decals and it came off real easy.
Gpokluda
