counter top laminate peeling |
Page <12 |
marwayne ![]() Senior Member ![]() ![]() Joined: 25 Oct 2011 Location: Edmonton AB Can Online Status: Offline Posts: 1004 |
![]() ![]() ![]() ![]() Posted: 10 Nov 2021 at 7:42pm |
Well, if you lived next door to me, I might consider it.
David and Danette ![]() podders Helping podders - pHp ![]() ![]() Joined: 24 Nov 2009 Online Status: Offline Posts: 1225 |
EchoGale you could park in marwayne's driveway with your camper that would be like living next door.
Edmonton might be a little nippy for you this time of year...
I agree with GlueGuy, if the partical board has gotten wet it will need to be replaced, there is no getting things to stick to that stuff if it's been damaged and is swollen. If a trip to Edmonton is not an option then maybe try a local shop that does laminate kitchen countertops. It shouldn't seem like a big job at all to those guys. An RV shop will charge you an arm and half a leg. But sure to have them use plywood and not more crappy particle board. It will inevitably get wet and swell again. |
I replaced the counter top in our r-pod 171 and our forest river Vibe with plywood the mdf that forest river uses doesn't work well if it gets wet. When I replaced the sink in our Gulfstream Vista cruiser I was happy to discover Gulfstream used plywood something more RV manufacturers should do.
Page <12 |
