  New Posts New Posts RSS Feed: AC and Hot Water Heater
Topic ClosedAC and Hot Water Heater
Ron54 View Drop Down
Direct Link To This Post Topic: AC and Hot Water Heater
    Posted: 24 Jul 2021 at 1:01pm
Can you Run the hot water heater and the AC on a generator on a 177?
mjlrpod View Drop Down
Direct Link To This Post Posted: 24 Jul 2021 at 3:17pm
Loaded question. If you have a big enough genny, you can run both, even with h/w set to electric. If you run the h/w on propane, it will require very little electric, so a much smaller wattage is needed. If you have an easy start, you could probably run the a/c and h/w on propane, with a 2000 watt. but it would be tight. You would probably need to turn of the charging side of the converter.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 24 Jul 2021 at 3:56pm
You would need a 3.5kw generator minimum. The water heater element is 1440 watts or about 12A, the a/c is about 15-16 amps.
But why would you? You will use much more fuel converting it's energy to electricity in the generator (which is only going to be about 20% efficient) than you would just to burn propane directly in the water heater (about 80% efficient).
Direct Link To This Post Posted: 24 Jul 2021 at 9:36pm
Thanks!!
Direct Link To This Post Posted: 24 Jul 2021 at 9:37pm
Thanks!
