  New Posts New Posts RSS Feed: What's This?
Topic ClosedWhat's This?
MikeP View Drop Down
Direct Link To This Post Topic: What's This?
    Posted: 23 May 2021 at 5:29pm
Any ideas what this is?  I was greasing the bearings and noticed this. Appears to be a clip of some sort. it moves fairly easily side to side but is connected to something.  I didn't see anything like this the other side,so I'm not sure what to make of it.  Appreciate any thoughts.
MP2112
Direct Link To This Post Posted: 23 May 2021 at 5:52pm
What you have is a cotter pin that runs through the axle; it purpose is to hold the castle nut in place which keeps the wheel and bearings tensioned properly.  You will need either needle nose pliars or sidecut pliars to remove and replace with a new one.
Better make sure there is a cotter pin on the other side as well as castle nuts normally don't come as a 'nylock.'  Without the cotter pin holding the castle nut in place the wheel could eventually fall off the axle . .  . not good.
Direct Link To This Post Posted: 24 May 2021 at 1:28pm
very useful info. thanks a bunch
MP2112
