  New Posts New Posts RSS Feed: 12 VDC FURNACE VS. A/C FAN
Topic Closed12 VDC FURNACE VS. A/C FAN
TEDDY View Drop Down
Direct Link To This Post Topic: 12 VDC FURNACE VS. A/C FAN
    Posted: 03 May 2021 at 10:22am
I have a 2017 r-Pod 178 - love it.  No leaks so far!
The 12vd/propane furnace is controlled by the electronic thermostat.
I'd like to be able to run the furnace without having the roof/ceiling A/C blower on.  Is there a way to do this?  There does not seem to be a way on the thermostat.......
I have not tried flipping the A/C breaker - and I think that would be bad practice anyway.
Suggestions?
Teddy
podwerkz View Drop Down
Direct Link To This Post Posted: 03 May 2021 at 12:20pm
Turn your thermostat off, then select FAN mode. Now use the up/down arrows and select AUTO. Then select HEAT mode and the A/C fan unit should stay off.
It goes without saying it but the A/C fan will not run when un-plugged from shore power, so if you are 'boondocking', then you can leave the thermostat fan setting in LOW or HIGH, as well as AUTO.
Direct Link To This Post Posted: 03 May 2021 at 3:19pm
Tks, podwerkz - I'll try the thermostat/fan routine.
Yes, I know dry-camping (no shore power) will work the way I want it to - I just never thought about how to get the heater to work w/o the A/C blower when hooked up to shore power!
Thanks again!
Teddy
Direct Link To This Post Posted: 03 May 2021 at 3:28pm
Yeah I installed two 500w electric heaters to use when on shore power so the propane furnace will never be used when plugged into shore power...but I understand sometimes  you do need to run the propane furnace even tho you have 30 amps of shore power available.
I believe the dometic thermostat works the way it does because some roof A/C units have heat strips for auxiliary heating when plugged in to shore power.
