steandstel ![]() Newbie ![]() ![]() Joined: 19 May 2018 Location: Cochrane Online Status: Offline Posts: 17 |
![]() Posted: 18 Oct 2020 at 6:25pm |
I dawdled and did not winterized my 171, I had emptied the hot water tank removed the anode and the 2 lower drains though. I have the heater on and got cold water lines working to my kitchen sink and outside shower
No hot water taps or toilet flush or sink / shower though - I have switched the hot water tank bypass on Any advice appreciated
Yikes, and it doesn't look like its going to warm up much anytime soon where you are. Hopefully leaving the furnace on for awhile has helped. Maybe take a heat gun on low or a hair dryer and try to warm up the plumbing lines where you suspect them to be frozen? You could also try connecting your water supply line to a hot water source and seeing if that helps get things thawed out.
Thanks for the reply I have all but one tap working now and have the heaters on as we speak/ type
Good. Once you get them working inspect carefully for leaks, especially at all the fittings and fixtures. Do the same in the spring when you de-winterize. You don't want water damage in an rPod, that can destroy a trailer very quickly.
tcj ![]() Senior Member ![]() ![]() Joined: 05 Jul 2018 Location: Central WA Online Status: Offline Posts: 141 |
How frozen pipes burst. Ask this old house https://www.youtube.com/watch?v=AuPO5hKdo8A
2018 R-pod 180 Hood River Edition
