jrastet ![]() Newbie ![]() ![]() Joined: 02 Aug 2020 Online Status: Offline Posts: 2 |
![]() Posted: 03 Aug 2020 at 4:18pm |
I have a 2016 model 178 and over time the door started to rub on the top left (opposite hinge). It has become harder and harder to close the door while at the same time the friction hinge is getting tighter. Now, the latch is in the way! I plan to lube the hinge which may free up some room to close but I fear there is a bigger problem.?#* No accidents. Any thoughts, ideas, fixes?
JR
I have a 2015 178 and have had door issues, I do not have the friction hinges. Is this happening when it is on the stabilizers or you believe it is level, or when it is just sitting on tires? If just on tires, look at your hinges and make sure they are tight. Make sure the latching mechanism is working correctly, and lastly try to determine where door is binding. On mine I tightened the door hinges. Adjusted the latch.
If that doesn't work, remove the bottom hinge screws, and see if you can move door to close with bottom pushed towards close and top pushed towards frame. If so it may be a case of shimming bottom hinge.
Does not seem to be related to stabilizers up/down, although I thought to try each corner to see if the problem changes. I'll double check hinge screws with tool. They appear OK. Thanks
JR
Maybe not, but unlevel can give you door issues, just a thought.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6417 |
I had some problems there also. I ended up filing down the door so that it would clear the frame. It was getting so it would bind the door and I did not like that it looked like it was going to break something. After I filed it, I repainted the frame and door to match the rest of the finish.
