Jensen LED light |
Post Reply | Page 12> |
packsmen
Newbie Joined: 31 May 2022 Online Status: Offline Posts: 1 |
Post Options
Quote Reply
Topic: Jensen LED light Posted: 15 Jun 2022 at 5:25am |
Hello, fffriedl! If I remember it right, you can find a switch at the bottom of the LED light lamp for this model. In my opinion, the Jense model of LED lights is not so good, especially the switches position if awful for me. Right now, I have replaced all lamps and bulbs around my house with smart strip lights because I find the LED strip lights more effective and cheaper. Also, I don't need to search for switches and connect more wires around my house, and also, the led strips are cheaper than the LED lamps and bulbs.
crw8sr
Senior Member Joined: 12 Oct 2017 Location: Omaha Nebraska Online Status: Offline Posts: 328 |
Post Options Quote Reply Posted: 18 May 2020 at 9:33am |
Thanks StephenH! Now I can stop using "Frog" tape to cover it up.
Chuck & Lyn
Izzy, Morkie. RIP Zoe Joy & Gracie, Yorkie 2018 R Pod 190 2019 Traverse In moments of adversity;when life's a total wreck, I think of those worse off than me and really feel like heck. |
Post Options Quote Reply Posted: 18 May 2020 at 7:51am |
+1 to StephenH's solution. The electrical load on the Jensen is not significant enough to be an issue boondocking, and the built in dimming function works just fine.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6290 |
Post Options Quote Reply Posted: 18 May 2020 at 7:32am |
On the Jensen unit, there is an easier way to turn off the light. The two arrow buttons to the left of the display adjust the brightness. The light can be turned all the way off there. I usually keep it at the lowest setting, just above off. That does not address the parasitic draw, but it does help at night. Also, I installed a curtain at the opening to the bed in our 179. That is to let me get up earlier than my wife, who likes to sleep in later.
Tars Tarkas
Post Options Quote Reply Posted: 18 May 2020 at 12:05am |
This is a fine solution for getting the light to turn off at night when you don't want to see it, but just be aware that it does little to prolong your battery life. TT
FJ Cruiser |
fffriedl
Newbie Joined: 17 May 2020 Location: Phoenix, Az Online Status: Offline Posts: 4 |
Post Options Quote Reply Posted: 17 May 2020 at 9:48pm |
Do you remember what color the wire is that you installed the toggle?
Frederick F Friedl
fffriedl
Post Options Quote Reply Posted: 17 May 2020 at 9:47pm |
Thank you. Very ingenious. I will install one too
Frederick F Friedl
Pod People
Post Options Quote Reply Posted: 17 May 2020 at 9:05pm |
We boondock a lot and I did not want his light to be active. I installed an in-line switch on the main power line going into the entertainment unit. I unscrewed the face of the unit and pulled it completely out of the wall. This will take 2 people because all of the wiring is relatively short, so 1 person has to hold the unit while you work on it. I found the main incoming power line and cut it. I added a simple on/off toggle switch in this line and reinstalled the entertainment unit back in the wall. I made a base plate for the switch(also holds the end of the curtain between the bed and living area). It works perfectly. Vann |
fffriedl
Post Options Quote Reply Posted: 17 May 2020 at 6:20pm |
Gotcha......Thank you
Frederick F Friedl
Tars Tarkas
Post Options Quote Reply Posted: 17 May 2020 at 6:05pm |
No. But there are also other parasitic 12v draws. The fridge computer board runs on 12 v no matter how it's powered, and the CO detector. Maybe that's it. The answer is to store the pod with shore power hooked up, remove the battery, or install a battery cut-off switch. TT
FJ Cruiser |
