  New Posts New Posts RSS Feed: winterizing
Topic Closedwinterizing
grizwalsh View Drop Down
Direct Link To This Post Topic: winterizing
    Posted: 07 Oct 2019 at 9:51am
Hi--I remember a photo of a water pump set-up under the bed of an r-pod but I can't seem to find it--any suggestions--Thanks
grizwalsh
Direct Link To This Post Posted: 07 Oct 2019 at 3:02pm
Don't know what model you have.  My 177 it is located under the sink on the floor.  Easy way to find it is to turn the water on, the pump will kick on and your ears will tell you its location.  Obviously you will have to have some water in your FW tank to do this test.
crankster78 View Drop Down
Direct Link To This Post Posted: 07 Oct 2019 at 3:12pm
Greetings :
Just about every model has the pump in a different location.  Look underneath the RV, find the white tank and it will be located above that.  My R-179 has it located between the furnace and the water heater under the bed.
Crankster78
Crankster 78 R-179 2015
Direct Link To This Post Posted: 07 Oct 2019 at 5:00pm
Thanks for the info
grizwalsh
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 07 Oct 2019 at 6:12pm
You will likely have to unscrew and remove some plywood kick panels to get to it.
TT
FJ Cruiser
