CPAP |
Post Reply | Page <12 |
EchoGale
Senior Member Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 461 |
Topic: CPAP Posted: 01 May 2019 at 8:09am |
Thanks!
Julie
Taospod
Newbie Joined: 30 Jul 2016 Location: Taos, NM Online Status: Offline Posts: 12 |
Posted: 02 May 2019 at 4:00pm |
Check a site called cpap.com. Back in 2016 I purchased a "DC Converter 24V 90 Watt for S9 Machines" to power my S9 ResMed CPAP unit. The converter package included a cigarette lighter plug, the converter brick, and wires to connect the brick to the CPAP machine. The package also provides wires with alligator clips if you want to go directly from a battery. The unit cost $84.95 at that time. Also check www.cpap.com/productpage/dc-conveter-for-s9-machines.html which provides detailed information with regard to current draw at 12v DC, battery amp-hour requirements for different treatment pressures and a lot of other good information. The unit has worked very well for me. The 800 number for cpap.com (at least in 2016) is 800-356-5221. I would guess they make converters for many ResMed series machines. Good Luck.
Jeepinator
Groupie Joined: 08 Sep 2017 Location: Seacoast NH Online Status: Offline Posts: 72 |
Posted: 05 May 2019 at 1:27pm |
Offgrid is correct. I have the same cPap and that is what I used. I installed a cigarette lighter outlet on the panel under the bed. You may want to upgrade to better batteries though; you don’t want the battery(s) to discharge less than 50%. You’ll also want to shut off the humidifier. It’s a major power hog. You may find this useful - https://www.cpapsupplyusa.com/PDFs/resmed%20batteryguide.pdf
2018 Jeep Wrangler Willys
2017 179 |
