  New Posts New Posts RSS Feed: keder welt for tarp
Topic Closedkeder welt for tarp
Pod People View Drop Down
Direct Link To This Post Topic: keder welt for tarp
    Posted: 22 May 2018 at 8:33am
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 22 May 2018 at 8:37am
I made a tarp that worked , but was a aping . I used sail slugs that were zip tied to a stand 10x12 tarp.  the sail slugs were too much trouble-didn't slide smooth, got jumbled in one place, got stuck on screw heads, etc, etc.  the project overall worked well once installed, but a pain to put up.
i plan on using a standard heavy duty poly tarp and sew the keder welt on one side.  I have 3 poles on the outside edge and a cross pole that I will use as a ridge perpendicular to the pod.  I will try to post pictures after I finish the project.
Vann
Live2Camp View Drop Down
Direct Link To This Post Posted: 22 May 2018 at 8:52pm
Vann
That sounds like a good approach! And the HD poly should hold up for a long time. But if it does ever wear out, you could just remove the keder and put it on the next one. That keder welt is seriously tough! You could remove the stitches (especially if they're a little longer) or even just cut it off and stitch it on to the next tarp. What type of sewing machine are you using?
2017 R-Pod 179 HRE (the green one)
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
