  New Posts New Posts RSS Feed: moving spare tire
Topic Closedmoving spare tire
lgblau View Drop Down
Direct Link To This Post Topic: moving spare tire
    Posted: 06 May 2018 at 1:15pm
Other than increasing the CCC of the R-Pod, by what 30lbs, is there a good reason to remove the spare tire, and mount from the TT to the TV. What about the TW.
Leonard🌵
2017/179
2017 Ram 1500
Tom A View Drop Down
Direct Link To This Post Posted: 06 May 2018 at 3:08pm
I moved my spare to the inner front storage area.  Is that a bad idea?
It allows me to hang my bike rack in the original rear spare tire receiver tube.   It also gives me more room in my parking spot.
2018 Sequoia--2018 RP 190
Direct Link To This Post Posted: 06 May 2018 at 3:35pm
Hi TomA...Sounds like a good reason to me, but does that not add to the TW.
Leonard🌵
2017/179
2017 Ram 1500
mcarter View Drop Down
Direct Link To This Post Posted: 06 May 2018 at 4:16pm
Anything added forward of axle adds to TW, proportionally. Proximity to tongue is more, toward axle is less.
Direct Link To This Post Posted: 06 May 2018 at 5:43pm
This is understandable, of course, but is it a problem if the tongue weight still remains safely below the maximum rating?
Direct Link To This Post Posted: 07 May 2018 at 7:33am
Simple answer is no. Best to allows know what you're tongue weight is. Then you can adjust or equip to compensate if it gets heavy. The maximum rating is very important not to exceed.
Capt Kidd View Drop Down
Direct Link To This Post Posted: 07 May 2018 at 11:37am
The Pirate's Pod
Direct Link To This Post Posted: 07 May 2018 at 11:38am
I solved this by installing a BAL hide a spare under the rear of my 179.
The Pirate's Pod
