  New Posts New Posts RSS Feed: Corrosion Under Trailer
Topic ClosedCorrosion Under Trailer - Event Date: 13 May 2017
DaveS View Drop Down
Direct Link To This Post Calendar Event: Corrosion Under Trailer
    Posted: 13 May 2017 at 2:54pm
Hi
 So as I am doing my de-winterize and spring maintenance I am looking at rust on the frame of my 178.  I find I have rust of some degree on all the under metal frame, worst where the angled supports are than the rest but some on all metal frame members.  I was wondering what northerners are doing to maintain? I assume mine is from salt as I had to drive it on some roads in the winter?  I did wash it and try and spray things down but apparently not effective.   Anyone have any good suggestions?  I did find No Corrosion spray online but not familiar with it and have no idea if that works?
Thanks for input,  Cheers Dave
sailor323 View Drop Down
Direct Link To This Post Posted: 13 May 2017 at 3:39pm
A light sanding to remove rust, not necessary to go down to bare metal.  Then paint on OsPho, it's a rust inhibitor available to Lowes, Home Depot and many other hdw stores.  It actually bonds with the rust.  2 coats may be necessary, then paint over with enamel.  Works great
mcarter View Drop Down
Direct Link To This Post Posted: 13 May 2017 at 3:53pm
+1, I use wirebrush, Extendes which is a spray rust inhibitor and good old rustoleum enamel. Inspect at beginning and end of camping season.
