Originally posted by macnim
Followed the Winterization posted by techtrek, posted Nov. 17, 2009. This was so wrong!!!! Lost the hot water heater and the toilet seal. $$$$$ later I provided this tip to the certified service tech and he was shocked but not surprised to see such an erroneous post. The anode rod has to be removed and the drain plugs left open. A very expensive lesson has been learned. I now wonder if techtrek has his own service repair company and he is drumming up business. This post should be deleted it is so wrong!!! |
He doesn't. That document has been followed by hundreds of owners without issue.
Having actually winterized quite a few times over the years, there is no issue I see with it. The anode doesn't need to be left out if the WH is drained and bypassed, and in fact I ALWAYS replace mine at the end of the procedure.
The toilet seal, and I admit I am not sure what you are talking about, nothing on the toilet is affected by winterization besides the plumbing itself.
I have to admit, I am not sure about "drain plugs left open" either.. but GUESSING you mean low point drains, and NO, they have to be closed in order to pump anti freeze through the system.
As far as what a RV tech told you.. having many years experience, I can tell you most techs don't know squat.
