Lubrication |
henryv
Senior Member Joined: 09 Feb 2017 Online Status: Offline Posts: 259 |
Topic: Lubrication Posted: 26 Apr 2017 at 6:07am |
Please tell me what, if anything requires lubrication...like the bathroom fan...
Posted: 26 Apr 2017 at 6:49am |
If you have a slide-out, it likely has a Schwintec mechanism. DoinyourselfRV has a video on how to lubricate that. I also lubricate the rollers that support the slide from underneath.
Your steps need lubricating as will the jack screws on your stabilizer jacks along with the pivot points. There isn't much else that needs lubrication. The Fantastic Fan in the bathroom should not need to be lubricated. However, you may need to lubricate the lifting mechanism for the cover if it is sticking. I have found it necessary to lubricate the door hinge, especially after our winter trips where there was road salt. The hinge is supposed to be stiff to hold it in place. However, it had gotten extremely stiff and was not moving smoothly. I used some lubricant with Teflon and it helped. While you are at it, give the locking mechanism a shot also. I can't think of any other places that need lubricating. If there are, someone else will post it, I'm sure. |
Richand Cindy
Senior Member Joined: 16 Apr 2016 Location: New Jersey Online Status: Offline Posts: 328 |
Posted: 26 Apr 2017 at 7:26am |
While not exactly lubricating our dealer told us to frequently use CAMCO slide out conditioner on the rubber. This prevents it from drying out, cracking and leaking. He also said whenever you use the slide out check to see the rubber is all aligned in one direction facing out. Sometimes a piece gets stuck in and will allow water in. Just stick your finger in and pull it out. Sure enough on our first trip there were two spots where it stuck. When we got home we cleaned the rubber (they were very dusty) put on the conditioner and no more sticking.
NEW: 2018 Passport Elite 23RB + 2017 Ram 1500 Diesel |
texman
Senior Member Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Posted: 26 Apr 2017 at 8:34am |
I know the wheel bearings need grease, but not clear on how often. i am thinking about every 5000 miles but need some feedback on that recommendation from the forum.
Rustler
Senior Member Joined: 07 May 2016 Location: S. Oregon Coast Online Status: Offline Posts: 100 |
Posted: 07 May 2017 at 3:18am |
The recommended wheel bearing repacking interval is in the packet of manufacturer's information that came with your Rpod. I don't remember what that was. But check there. I need to figure how many miles I towed last year to see if my RPod 171 needs grease.
Russ
2009 Toyota RAV4 V6 w/ tow package 2016 Rpod 171 HRE |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3221 |
Posted: 07 May 2017 at 3:58pm |
I do mine 1x/year in the spring.
Weekend Warrior
Newbie Joined: 05 Nov 2016 Online Status: Offline Posts: 35 |
Posted: 10 Oct 2017 at 12:03pm |
Here is the link to everything you need to know about the Lippert axles used on Rpods as well as the greasing intervals based on the axles weight. Also you will find the part numbers for the replacement bearing and seals as well as the proper grease used in repacking bearings. https://www.lci1.com/assets/content/support/manuals/Axles%20and%20Suspension/Trailer_Axle_2K_7K_Owner_s_Manual__half_book_.pdf.
Weekend Warrior
Posted: 10 Oct 2017 at 12:08pm |
Page 30 clearly states the bearings need to be inspected and repacked at 12,000 miles or yearly, which ever comes first.
Weekend Warrior
Posted: 10 Oct 2017 at 12:11pm |
This link will take you to the Lippert axle site which clearly explains all your questions.
