  New Posts New Posts RSS Feed: Low Water Pressure At Kitchen Sink
Topic ClosedLow Water Pressure At Kitchen Sink
PodWa View Drop Down
Direct Link To This Post Topic: Low Water Pressure At Kitchen Sink
    Posted: 24 Apr 2017 at 10:10am
We had good water flow in the bathroom of our 2017 RP179, but very weak flow at the kitchen sink.  I removed and disassembled the screen filter on the faucet to check for debris.  Yes, I found some.  I also found three screen disks stacked one upon the other in the filter unit.  Could this have been intentional?  No wonder water flow was restricted!  I cleaned the filter and removed two of the screens.  Now water flow is restored!  Hope this saves someone a little time and trouble.Tongue
john in idaho View Drop Down
Direct Link To This Post Posted: 24 Apr 2017 at 11:07am
The good part is that you now have 2 spares.
Direct Link To This Post Posted: 24 Apr 2017 at 11:57am
The stacking of the screens IS intentional.When living with a 30gallon holding tank, limiting flow is a plus. If you always camp with FHU's.. then not an issue.
Direct Link To This Post Posted: 24 Apr 2017 at 1:02pm
Thanks, FurPod!  That makes sense.  Perhaps, the combination of the three screens and a little debris caused water flow to slow to a trickle.  I might try the screens again.
Direct Link To This Post Posted: 24 Apr 2017 at 8:11pm
I noted that we have 3 screens in ours as well.  Since our well water is very clear, and we don't use anyone else's water, we have never had an issue with the screens plugging up.  I do check them however once/year just to make sure.
gunny View Drop Down
Direct Link To This Post Posted: 25 Apr 2017 at 10:51am
Thank you for your post. I went out and checked my 177, and i had 4 screens.
Why would they do that.
Direct Link To This Post Posted: 25 Apr 2017 at 11:47am
I think FurPod got it right...they are there to partially restrict flow to limit water use and keep the grey water tank From filling too quickly.  Our water flow at the sink had slowed to only a small trickle which caused me to check the screens.  I originally removed two of the three screens, but replaced them after FurPod's analysis.  Now I have acceptable, but somewhat restricted flow.  I guess that it does not take much debris and three screens to really slow the flow.
mcarter View Drop Down
Direct Link To This Post Posted: 25 Apr 2017 at 4:24pm
When in a full service campground, not worried about gray tank filling. When truly boondocking, I do my dishes in a pan or use the outside shower faucet for light clean up. My experience has been the water pressure is more dependent upon the water pressure from the spigot, and if that is to low I fill the fresh water tank and use the water pump. I look for 45lbs when I set up. I took my faucet apart after this post, it has one screen.
PilotPodder View Drop Down
Direct Link To This Post Posted: 22 May 2017 at 4:34pm
Thanks for posting this. Just ran into this same problem on my new 179 while out camping. Pulled the screen apart and found considerable construction debris causing obstructions! Much better now.
Fredness View Drop Down
Direct Link To This Post Posted: 03 Aug 2019 at 4:24pm
The "debris" is chunks from you zinc anode in the water heater.
Might want to check that...
And flush the water heater with a wand.
