  New Posts New Posts RSS Feed: CAMCO  59123 4-port Propane Adaptor
Topic ClosedCAMCO 59123 4-port Propane Adaptor
mcarter View Drop Down
Direct Link To This Post Topic: CAMCO 59123 4-port Propane Adaptor
    Posted: 25 Mar 2017 at 4:51pm
Installed my CAMCO 59123 4 port brass T adaptor to Pod today. 80 bucks at Amazon with TN tax. Very easy install, took less than 5 mins. Attaches to you LP tank directly and then you put your Pod system back on the end port. It does nothing to effect you current propane system. What it provides is two extra ports. The kit comes with a 5' and a 12' hose(s). The 12' hose is adaptable to your current Weber or Coleman grill that uses the small bottles, so you can run you grill off the propane tank, with another adapter, not included in kit you can adapt that hose to a portable campfire per say. The last port with 5' hose allows you to connect to an aux propane tank without drawing on your mounted tank, which is cool if you just want to carry a tank to run off for days at a time, much easier to replace. The ports are sealed when not in use and you do have to take some precaution like not leaving your grill on. Common sense stuff. I give it an A+ for install and function.
Thanks Mike
