  New Posts New Posts RSS Feed: brake wires loose
Topic Closedbrake wires loose - Event Date: 17 Mar 2017
jimhibb View Drop Down
Direct Link To This Post Calendar Event: brake wires loose
    Posted: 21 Mar 2017 at 2:28pm
Hey y'all, thank you for your help and suggestions. talked to a service tech where I bought the TT, it doesn't make any difference which wire goes where. Furpod you had it right - good job. got the wires connected and we are ready to travel. this is a great forum and a great resource, thank you.
Jim
Jim
we are semi-retired happy campers
2015 R-pod rp 178
2015 frontier club cab v6
Jim n Kathy
Charlie girl a wacky jack russel
Direct Link To This Post Posted: 20 Mar 2017 at 12:30pm
It's actually a simple electromagnet..I do not believe they are current dependent. ie: the +/- don't matter, that's why both wires are the same color.
Direct Link To This Post Posted: 20 Mar 2017 at 11:36am
thanks for the reply furpod, I wish it was that simple. I have 2 green wires coming out of the passenger side brake back plate and 1 white wire with a black stripe and a black wire with 2 white stripes that I need to connect to the green wires... the tt is a 2015 rp178... very confusing... I thought of connecting them up to see what would happen but I'm not sure if that would cause more problems
Mike that is what I intended to do, thanks for the encouragement...
Jim
2015 R-pod rp 178
Jim n Kathy
Direct Link To This Post Posted: 17 Mar 2017 at 5:41pm
Also suggest you replace the tie wraps with a heavier grade, after your repairs. Some heavy duty tie wraps will give you more confidence in the hook up.
Direct Link To This Post Posted: 17 Mar 2017 at 3:35pm
It's the same on both sides, so white to white and black to black
They get hit by road debris etc, and sometimes pull loose.
Direct Link To This Post Posted: 17 Mar 2017 at 2:31pm
I have just noticed that brake the wires on the back of my passenger side wheel are not connected. I do not know which wire to reconnect to which wire... Help pleaseEmbarrassed
jim
Jim
2015 R-pod rp 178
Jim n Kathy
