Replacing Bat Wing antenna - Event Date: 07 Mar 2017 |
P and D Podders
Newbie Joined: 04 Mar 2016 Location: georgia Online Status: Offline Posts: 24 |
Calendar Event: Replacing Bat Wing antenna Posted: 07 Mar 2017 at 10:56am |
The batwing antenna on my 179 has bent and needs replacing. I was looking at a King Omnipro, omni directional antenna as a replacement. Have any of you had any experience with this antenna? Have any of you replaced your batwing with one of these? Is there anything I need to know before I buy and install one of these?
P and D Podders
TheBum
Posted: 07 Mar 2017 at 11:58am |
If I were to replace the antenna in our 179, I'd get a King Jack antenna and not another omni-delusional antenna (an omnidirectional antenna only guarantees that you'll get bad reception in all directions). Unfortunately, it would also mean moving the location of the antenna because the directional knob would be in the airspace behind the stereo otherwise. I've actually considered doing this, but with DIRECTV NOW streaming over AT&T wireless, my interest in doing so has waned.
Podster
Posted: 07 Mar 2017 at 7:19pm |
You might get a signal acquisition performance bump if one of the bat ears is now vertical.
Cliff & Raelynn
Posted: 07 Mar 2017 at 7:55pm |
An alternative to moving the antenna would be to cut an opening through which the antenna's controls could be reached and worked. It might involve relocating the items that would be in the way (outlet, antenna booster, etc. If you have any skill in making this type of modification, it might be a viable option.
TheBum
Posted: 08 Mar 2017 at 2:42pm |
After I posted, I thought of rigging up a stepper motor controlled by a potentiometer mounted to the wall. The stepper would turn the knob in response to turning the pot. The mod would also require bringing out the signal strength indicator lights to where they could be seen.
