  New Posts New Posts RSS Feed: 2017.5 tire and wheel upgrade
Topic Closed2017.5 tire and wheel upgrade
zappapod View Drop Down
Direct Link To This Post Topic: 2017.5 tire and wheel upgrade
    Posted: 16 Apr 2017 at 7:25am
Good suggestion.  Thanks.
2017.5 178 (Blue Bell)
2005 Tundra Double Cab
Outer Banks Bound
computerfixitguy View Drop Down
Direct Link To This Post Posted: 16 Apr 2017 at 12:36am
I bought these ; Save A Jack; https://www.amazon.com/Mounting-Brackets-Attachment-Release-Protector/dp/B005ZI03GS
My stabilizers now just come off and store in the trailer because I got tired of hitting the ground.
Derek
Direct Link To This Post Posted: 24 Feb 2017 at 8:30pm
thanks for the suggestions.
Outer Banks Bound
finder9 View Drop Down
Direct Link To This Post Posted: 24 Feb 2017 at 7:57pm
Ask the dealer to move the rear stabilizers (they are bolt on) forward about 18 inches.  They should do it for free.  Does not affect function and eliminates dragging.  Solved my goofy driveway problem well.
Jack
2017 Rpod 179
2015 Dodge Ram
Our pod View Drop Down
Direct Link To This Post Posted: 24 Feb 2017 at 7:09pm
If you do upgrade, consider Load Range D.
Life is good.
Direct Link To This Post Posted: 23 Feb 2017 at 10:22am
Thanks, that is helpful information.  Perhaps I will wait until I take delivery and get someone local to look at and advise.  Sixteens would be awesome but the new axles no longer accept risers (aren't supposed to need them anymore).  Maybe I will have a brand new set of fourteens to sell!
Outer Banks Bound
CharlieM View Drop Down
Direct Link To This Post Posted: 23 Feb 2017 at 9:45am
Don't get too excited about the 14" to 15" conversion. For the same size tires (tread width and sidewall ratio) the difference is 1" diameter or 1/2" radius. That's only 1/2" added ground clearance at the axle. The important number is the overall diameter of the tire. Most clearance issues are at the rear of the trailer such as driveway or gas station dips. The risers will yield more improvement in ground clearance. However, there are many more tire options available with 15s but you must consider the cost of the new wheels. The big improvement would be 16" rims but, without the risers, you may run into fender clearance issues.
Direct Link To This Post Posted: 23 Feb 2017 at 9:32am
We pulled our 2011 177 about 30,000 miles, no risers. Drug once or twice going into gas stations.. go slow, pay attention. If it looks iffy, go on to the next one. My biggest worry was always hanging a wheel on a barrier or something, not scraping the bottom.
Direct Link To This Post Posted: 23 Feb 2017 at 9:13am
Discretion is always key.  But, perhaps better equipment allows for better results when discretion fails.
Outer Banks Bound
Direct Link To This Post Posted: 23 Feb 2017 at 8:57am
We have traveled quite a few mountain roads over the Rockies and off roads as well with our 2011 model 177 with the 14 inch wheels and NO risers, so the pod sits pretty low.  The only issue we have had are some filling stations with a somewhat severe incline as we exit the main road and have scraped the back stabilizers a few times, but not to the point of tearing them off.  I have done that in our backyard and also in the UP of Michigan once when I went into an area I shouldn't have; bent them pretty bad, but figured even if I had the risers, the same thing would have happened.  Just went into an area that I shouldn't have, it is called driver discretion, which that time I lacked big time.
