  New Posts New Posts RSS Feed: Tool box
Topic ClosedTool box
Direct Link To This Post Topic: Tool box
    Posted: 27 Feb 2017 at 4:39pm
How about a tube of Flex Seal, not an endorsement:)
Happy Tripping View Drop Down
Direct Link To This Post Posted: 27 Feb 2017 at 4:28pm
This is a little late, but ....
One absolutely vital 'tool' that a new person to podding might not consider is a portable air compressor to keep the tires of the trailer and tow vehicle up to proper pressure.
ribet View Drop Down
Direct Link To This Post Posted: 15 Feb 2017 at 9:04pm
Crazy glue,  epoxy cement,  cheep ohms meter.  Just a thought,  I think Harbor Freight was conceived for us rPoders.
Steve 911 View Drop Down
Direct Link To This Post Posted: 15 Feb 2017 at 4:40pm
On ice 👍🏻
Firefighter Steve (retired)
2017.5 Rpod 179 (Reepod)
2016 Highlander AWD w/tow pkg.
E2 wdh, prodigy RF brake controller.
Direct Link To This Post Posted: 15 Feb 2017 at 4:38pm
ooops almost forgot...............................a 12 pack of silver bullets  to go with the first aid kid purely medicinal Approve
Direct Link To This Post Posted: 15 Feb 2017 at 9:36am
Originally posted by StephenH
Some tools recommended are not essential (such as an ax) but some will be needed if you need to change a tire.... The key is to find the balance between the desire to take everything you might need vs. the space and weight all those things will require. What that point will be depends on you.
Ah, with respect, I firmly believe an axe is the ONE thing that everyone should have. Yes it's a tad heavy, but it lays down flat in the slide-thru, taking up very little space. It was said of the pioneers that one could go into the wilderness with only an axe and come out a year later with a team and wagon. An axe can help in setting up camp and with fire wood, and when you are really in trouble because of a blow down in the road or a deep mud hole, it's there  to save your bacon.
So let's shed a little respect on that valuable tool, the axe.
Direct Link To This Post Posted: 15 Feb 2017 at 9:22am
Originally posted by Leo B
I always keep a first aid kid handy Approve
Must be a boy or girl scout. LOL
We have a first aid kit in our car.
Direct Link To This Post Posted: 15 Feb 2017 at 9:05am
I appreciate everyone's comments.  Thank you.
I'm off the the hardware store....
Direct Link To This Post Posted: 15 Feb 2017 at 7:34am
Direct Link To This Post Posted: 14 Feb 2017 at 8:10pm
I agree with Bob and Joyce that a good general purpose tool set will have almost everything you need for tools. If you look for one where all the tools are in slots in a case, then you only have one item to store instead of a number of items and you can see that everything is in its place if all the slots are full. Some tools recommended are not essential (such as an ax) but some will be needed if you need to change a tire (hydraulic jack, lug wrench or impact wrench and torque wrench). The key is to find the balance between the desire to take everything you might need vs. the space and weight all those things will require. What that point will be depends on you.
I purchased a 12V impact wrench from Harbor Freight. It is slow as it has to spin up and take a hit, then repeat the spin up and hit, but it will remove the lug nuts. It is relatively light weight and does not take up much room. The jacking block I made to work with the hydraulic jack I purchased is detailed in my mods. I carry a 100 ft.lb. torque wrench also from Harbor Freight. I have a 1/2" drive extension and the same bit from the impact wrench fits that so I use that for lug nuts. Another Harbor Freight purchase was a 130 Piece Tool Set. With coupons and sales, I have gotten some good buys on these items and others.
