How do you screw stuff into the walls? |
Post Reply | Page 123 4> |
laureyrpod
Newbie Joined: 11 Feb 2017 Location: GA Online Status: Offline Posts: 28 |
Topic: How do you screw stuff into the walls? Posted: 11 Feb 2017 at 7:36pm |
I have a 182g which I love, and am dying to do some modifications. However, I am fearful of drilling holes into the rpod walls (interior). I see mods showing shelves which I want to do, but no one ever says how they actually affix the brackets to the walls. I have learned that you can search for the studs, so affixing things to the studs would be easiest. But what about when you aren't over a stud? Molly bolts? Any tips for brands or installation instructions? I'm handy but not overly so. Please be specific--tools needed, drilling?, brand or size of bolts....
Thanks in advance! Peace in the Pod (Laurey, Bella, and Bogie)
Laurey, Bella and Bogie
2016 182g Rpod 2016 Toyota Highlander "Peace in a Pod" |
coopercdrkey
podders Helping podders - pHp Joined: 26 Aug 2012 Location: Cedar Key, FL Online Status: Offline Posts: 457 |
Post Options Quote Reply Posted: 12 Feb 2017 at 6:06am |
I have had some success using the spiral sheet rock anchors in areas where no stud or metal framing was available.
These anchors have a pointed end designed to bore the correct size hole in sheetrock. I cut off the pointed end and pre-drill the hole. That reduces the length of penetration required. It also results in a "clean" hole that can be easily plugged if you decide to move or eliminate the bracket, etc. |
Bob and Joyce
Jennifer and Baxter, the Campin' Cocker Spaniels RP 177 "Key Pod" Chevrolet Silverado 1500 LT / Z71 |
Post Options Quote Reply Posted: 12 Feb 2017 at 2:45pm |
Crown Bolt Hollow Wall Anchors #6-32x1" (UPC: 0 30699 00469 0) works on wall thickness of 1/8" to 1/4" and since they are shorter than the thickness of the R-Pod wall, there is no danger of going through. Look for them at Home Depot.
Podinaroundbc
Newbie Joined: 26 Jul 2015 Location: Alberta Online Status: Offline Posts: 34 |
Post Options Quote Reply Posted: 12 Feb 2017 at 4:11pm |
We have put screws in our walls without searching for studs but we also don't hang anything heavy. We use small #6 wood screws. After 2 years everything is still attached.
Art & Brenda
Jake the dog 2015 179 HRE 2012 Nissan Titan |
mjlrpod
Post Options Quote Reply Posted: 12 Feb 2017 at 4:32pm |
So these definitely will only go thru the wall board stephen? no chance of popping thru outside wall? |
Post Options Quote Reply Posted: 12 Feb 2017 at 6:10pm |
I have a piece of wall that I removed in the door to install a window. The walls are NOT hollow like what you expect in your house when you put a dry wall anchor thru the drywall. There is a condensed foam insulation between the inside and outside wall(s). I want to try different anchors and see how they expand in that condensed foam. I can use that piece I cut from the door. There is about an inch and a half between inside and out side walls. You have to be careful when drilling from either side not to go thru the other side. You just want to pierce the interior wall. Same with hanging something on the outside, I have solar security lights motion lights I mounted. I use an old trick, when drilling anchor holes. I wrap electrical tape around the bit about a half inch from the tip, that stops the bit from going in more than about a half an inch. I'm using the bit that comes with the anchor set, I believe it is a 1/4 bit for a number 8 anchor. I have not used the anchors that Stephen suggests but I will test them now to see how they anchor in the condensed foam. I have used Crown Bolt anchors for many applications. Very secure. I don't use the walls in the RPod to hold anything of weight. Light bearing shelves are ok, but if I want to hang clothes for an example I use a closet rod above the window shade boxes so everything is load bearing. Then I attach the shelves to the closet rod so there is an assist to the shelf, if that makes sense. You do need a stud locator that warns of metal studs, if you do or don't want to use the existing studs. I haven't found any application where I could use the existing studs, different for everybody.
laureyrpod
Post Options Quote Reply Posted: 12 Feb 2017 at 7:01pm |
thanks, Cooper, I will give those a try. I tried several types of hollow wall bolts to no avail...they would not stay put. they wobbled then fell backward into the wall. I bought a special tool online (had to be shipped from the UK thru Amazon) and it was supposed to make installing hollow wall bolts a cinch. No luck.
Given the number of mods I see in this forum, I'm sure that there's a way to screw things into the walls! L. |
Post Options Quote Reply Posted: 12 Feb 2017 at 7:43pm |
Given that the walls are 1-1/2" thick, a 1" anchor will definitely NOT go through the outside. Don't make the mistake of getting the Short Hollow Wall Drive Anchors (with the pointed end). They will definitely go through the outside wall (speaking from experience ). Just be careful to only drill through the inside wall as described by Mike Carter. His idea to put a piece of tape on the drill bit is a good one.
Don't bother trying the "Toggler" anchors that look like wings. The foam makes it almost impossible to push the wings into position, which means that they can't perform adequately. |
marwayne
Post Options Quote Reply Posted: 12 Feb 2017 at 10:29pm |
The door is 1 1/2" and the walls are 1 5/16" thick
Post Options Quote Reply Posted: 13 Feb 2017 at 8:45am |
Again, thanks for the correction. I was assuming that the door and walls were the same thickness. Still, a 1-5/16" wall should be in no danger from a 1" fastener.
