How do you screw stuff into the walls? |
Post Reply | Page 123 4> |
marwayne
Post Options
Quote Reply
Topic: How do you screw stuff into the walls? Posted: 15 Oct 2021 at 11:25am |
I built a cabinet over the kitchen counter for dishes plus 2 towel bars and toilet paper holder in the bathroom.
Post Options Quote Reply Posted: 15 Oct 2021 at 9:20am |
For the upper attachment, I would definitely consider the short molly bolts to provide that additional support of the expanded fastener on the back side of the panel.
Post Options Quote Reply Posted: 15 Oct 2021 at 8:34am |
Re whether the foam does anything to help or not, it's normal in engineering practice when you have this kind is situation to just assume it makes no positive contribution to supporting the load. That is a conservative assumption but a good one.
Re pressure sensitive adhesive (PSA) tapes, they have been around for decades now. They can provide a strong bond if applied right and used in the right environment. If installed wrong or used under conditions they're not intended for they can fail badly. So if you use them follow the directions carefully. Personally, I don't trust them, having had some bad experiences with them. Mechanical fasteners have to be installed correctly too of course, but they are much more tolerant of varying temperature, humidity, and surface prep. I have no objection to LA's "belt and suspenders" approach of using both. Also don't be afraid to perform a test to see how strong your attachment is. It will have to hold up one way or another, might as well find out sooner rather than later. If you test you need to put the right amount of force on the attachments in the right direction, which requires a bit of thought. For example, upper attachments of shelf brackets primarily see pullout loads (because the weight on the shelf is trying to rotate the bracket outwards st the top) while bottom attachments mainly see pull over loads. The pullout loads are worse because of leverage from the shelf, so it's going to be the upper shelf bracket attachment that fails first. So if it's a shelf bracket it's best to install the bracket and pull down halfway out the bracket (where the center of downforce on the shelf will be) rather than directly on the attachments. Use a spring scale and pull down with about twice the weight you plan to put on that bracket to account for bump loads while driving. Hold the force for awhile. If it passes that test you should be good to go unless you're using PSA tape which fails later due to environmental conditions. |
lostagain
Post Options Quote Reply Posted: 14 Oct 2021 at 7:39pm |
Consider fastening a backing/mounting plate for shelves if you're going to put a lot of weight on them. It helps spread the load.
rawest50
Post Options Quote Reply Posted: 14 Oct 2021 at 7:35pm |
Thanks. How much weight did you put on the connection? I would like to install shelves.
2017.5 RPod 179
marwayne
Post Options Quote Reply Posted: 14 Oct 2021 at 6:42pm |
I have my pod since September 2010, no screw has pulled and no delamination.
rawest50
Post Options Quote Reply Posted: 14 Oct 2021 at 5:24pm |
I am not worried about the screw pulling away. More about the screw pulling the laminated planet apart.
2017.5 RPod 179
lostagain
Post Options Quote Reply Posted: 14 Oct 2021 at 10:51am |
The wall paneling is all there is to give resistance to the load. The foam really doesn't do much more than air. You are right in not trusting "command strips." They are not really designed to hold much weight, especially when it's subjected to the shake rattle and roll of a moving trailer.
It's too bad you can't get inside the wall to put big washers on the other side of the paneling to spread the load on the thin wood. The best you can do is to try to spread the load through other means. We've used the coarse thread and 3M extreme/super heavy duty mounting tape that claims to hold 90 pounds per inch [https://www.amazon.com/Double-HitLights-Mounting-Waterproof-Length/dp/B07TC16SZ7] with great success. The towel racks, paper towel holders, toilet paper holders, and so on, all are very securely fastened and show absolutely no sign of loosening after years of use. I speculate, but will leave it to our wise engineers to opine, that the foam helps dampen some of the forces exerted on the mounted stuff and the wall, thus helping it stay in place. But, of course, as I often am, I could be wrong. According to Mr. Google, applying Goo Gone will dissolve the glue on the tape for easy removal, if you decide to take what you mounted off the wall.
TheBum
Post Options Quote Reply Posted: 14 Oct 2021 at 10:30am |
The holes I'm putting in will be all in the bathroom of my 196 for items that should have been installed at the factory: towel bar, hand towel ring, toilet paper roll holder, etc. I don't trust Command Strips or threads through 1/8" paneling to hold those.
Alan
marwayne
Post Options Quote Reply Posted: 13 Oct 2021 at 7:35pm |
