hogone
Topic: generator cords Posted: 15 Jan 2017 at 7:42am |
im going to hook up my generator(8-10000 watts-generac) today just for grins!! I bought it 3 years ago and have never needed it for emergency backup. i do start it 3 or so times a year; put a light load on it and run for about an hour. i had it out and ready to go this weekend as we were expecting a pretty good ice storm which never materialized as expected. i want to run the cords in the house and hook various things up and put a full load on it for a practice run. does anyone have any other suggestions other than running cords thru an entrance door(my wife said i couldn't put the genset in the middle of the living room ). GO PACK
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted: 15 Jan 2017 at 8:48am |
Of course the ideal way would be to have a transfer switch wired in and a receptacle outside. That would cost more than your generator, so a lot of people don't do that. Otherwise though, you're right, you have to run the cords in somehow. A hole the wall, nicely finished, that you could stuff with insulation even when in use, and cover up neatly when not in use would be nice. After that, I guess there's not much choice but a door or window -- which have obvious problems during ice storm weather.
The nice thing about a transfer switch is that you can hard-wire circuits for things that don't have plugs, like a 220v water heater or water pump, etc. And of course it's a lot less hassle when the power goes off and comes back on.
hogone
Posted: 15 Jan 2017 at 8:57am |
ya, im not gonna hook up direct to the box quite yet. i have thought about a hole in a wall, actually in a cabinet which abuts to the garage wall!!for today i will just run in door, but i think a hole is forth coming. hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
mjlrpod
Posted: 15 Jan 2017 at 9:20am |
ok, heres how i did it before when we had an ice storm and we needed to use a generator for 5 days. I ran the power cords thru my dryer vent exhaust vent, into the house, then ran cords to each place i needed power. It worked out great. I stuffed a couple small hand towels around the powercord to block the cold air from coming in thru the opening since the cord wouldnt allow the cover to fully close. Its cheaper than some other options.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Craneman
Posted: 15 Jan 2017 at 9:34am |
You might want to rethink just running a cord in the house, I jerry rigged our house for year as our power goes out often. During a power outage years ago someone ran a line to a outlet and forgot to flip the main to off,which from what I heard resulted in a near miss for the power co workers. I went to home depo and for about $400 I installed a transfer switch. We can run everything in the house. Good luck
Jo and Gary
2010 174
2011 Ford 150
hogone
Posted: 15 Jan 2017 at 9:42am |
unfortunately my dryer is downstairs, i would want to power the upstairs which would mean alot of cords; excellent thought though. time to punch a hole in the wall. GO PACK. hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted: 15 Jan 2017 at 11:24am |
Originally posted by Craneman
You might want to rethink just running a cord in the house, I jerry rigged our house for year as our power goes out often. During a power outage years ago someone ran a line to a outlet and forgot to flip the main to off,which from what I heard resulted in a near miss for the power co workers. I went to home depo and for about $400 I installed a transfer switch. We can run everything in the house. Good luck |
Yeah, people do that, but that is not the way to go! Even if you're careful enough there are other electrical issues that are over my head, but one mistake can lead to dead linemen. A transfer switch is the first choice, but then going with cords from the generator directly to the appliances is next. TT
mjlrpod
Posted: 15 Jan 2017 at 11:41am |
Well, i ran power upstairs too. I had no ready made hole up there. I ran the cord to the window, and using the same idea, i stuffed the crack of the window with towels or insulation so the cold couldnt get thru the open bottom section of window. My window was on the second floor. I will do the same thing again if an emergency comes up. I hear they make some type of adapter that goes on your electric meter. I guess you plug your generator right into the adapter and it powers the house. Thats what i heard, no idea of anything else.
2020 R-pod 195
I'll be rpodding
hogone
Posted: 23 Jan 2017 at 5:36am |
my neighbor gave me another genset, wheelhouse 5500. runs excellent except the left side plugs ins arent producing juice. its not the breaker. ant easy troubleshooting fixes? hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
hogone
correction; right side plugins!! hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
