  New Posts New Posts RSS Feed: Our-Pod Mods
Topic ClosedOur-Pod Mods
GlennZippy View Drop Down
Direct Link To This Post Topic: Our-Pod Mods
    Posted: 06 Feb 2017 at 7:34am
Thanks. I can't take sole credit though: This site is a gold mine!
"Originality is the fine art of remembering what you hear but forgetting where you heard it."
2010 R-Pod 152
Direct Link To This Post Posted: 06 Feb 2017 at 7:22am
Great mods!
Direct Link To This Post Posted: 05 Feb 2017 at 6:40pm
Every Day Carry Wink
2010 R-Pod 152
osage View Drop Down
Direct Link To This Post Posted: 05 Feb 2017 at 5:17pm
where are the vice grips and baling wire
Direct Link To This Post Posted: 05 Feb 2017 at 1:48pm
Stumbled onto these "floor cushions" today at Costco for $20 each. We've been trying to figure out a way to make the front bed more into a couch and these worked out quite nicely! We added in the small pillows just to see how they felt and will look for some others down the road that will fit the color scheme we are thinking.
2010 R-Pod 152
Direct Link To This Post Posted: 04 Feb 2017 at 3:59pm
Kitting Up, Continued
We were VERY tempted to take the Pod out this weekend. Temperatures were going to be in the upper 50’s and lower 60’s but schedules and wind dictated a few more mods.
So continuing from my last set of mods, I finished my sewer kit. Once again, this kit goes into a plastic bin that fits into the outside storage area. This one has a clear 45 degree adapter, a coupler, nitrile gloves, a sewer adapter (with the other end already attached to a sewer hose) and a sewer hose support. This last item does not fit into the bin, but it seems to travel pretty well as is. My pod came with 2 sewer hoses, and I put a Valterra EZ coupler sewer hose connection shortly after it arrived.
Naturally, since I have 2 hoses, I checked to see if they would both fit in the smallish sewer hose holder and they would not. I wish I had checked that before I had put the tongue box on a few weeks ago as I had to take the box off to attach the second holder. It tucks in nicely behind the box and between the Pod. I shifted it a bit to the driver side since that’s where it would be used the most.
Continuing in the water vein, I swapped out the standard shower head with the Oxygenics Shower head. This was a pretty straightforward process where I removed the old hose and bracket and replaced it with the new one. The new one also came with a water cutoff switch that makes it easier to take a navy shower. My hope is that the hose will straighten out once I get some hot water running through it.
I also went ahead and swapped out the light bulbs in the Pod for LED lamps. Also a very easy process and took all of 5 minutes to complete. I kept the old bulbs and put them into my hardware box I discussed a few posts up.
A few small items were also added: A mirror (a must have for my wife), a cup-holder so that I have a spot for a water bottle at night when the dinette is turned into a bed, and a few strategic command-strip hooks.
2010 R-Pod 152
Direct Link To This Post Posted: 29 Jan 2017 at 8:26pm
A very thorough kit, thanks for sharing.
Direct Link To This Post Posted: 29 Jan 2017 at 4:02pm
Kitting Up
Since we tend to camp in places that are pretty out of the way, I decided I wanted to have a somewhat complete took kit. So here is my primary kit, and no: it doesn’t all fit into the toolbox.
Some items are stored in one of the drawers for quick access: The duct tape, one of the super glue tubes, scissors, tape measure, and the orange screw driver set. The drill, along with the stabilizer socket and the charger are stored in the outside storage area or, if I feel the need for more security, in the truck. The box of screws, the terminal set, the silicone, the lithium grease, WD-40, and spray paint are in a bin together. The rest fit into the toolbox nicely.
The toolbox and the bin with the chemicals and other items are stored under the bed up front.
Not pictured is a basic socket set that I picked up from Home Depot:
This also goes in the above bin as well.
I also worked a bit on getting all of my water stuff in the same place. So i have those items here:
The longer hose is stored loose, and the rest go into a bin together. Some parts are redundant (there are two pressure reducers shown) and I can't imagine needing the  water heater element wrench in the field, but better to have and not need than to need and not have!
I'm also working on a similar bin for my sewer bits and pieces, but I will wait for that another day.
2010 R-Pod 152
sean p View Drop Down
Direct Link To This Post Posted: 29 Jan 2017 at 11:54am
his route is perfect. i've towed that way several times. no sweat..
2016 179pod--BETTY
2010 nissan frontier
Sean and Doug
Butchie the morkie
touring the west
Direct Link To This Post Posted: 29 Jan 2017 at 11:34am
From the Springs to Canon City is not bad at all. A little twisty in parts but it's not a super big elevation difference. Highway 115 runs right along side Fort Carson and there's not a ton of services until you hit Highway 50. Passing lanes are here and there and watch out for motorcycles: The riders are typically young and stupid in that area.
Once you hit 50, it's a decent road but it does get pretty twisty, but is a good road with frequent passing lanes when it's not 4 lanes. Going in to Salida is one of my favorite stretches. Drop. Dead. Amazing. Surrounded by 14,000 foot mountains. One of my favorite spots.
Heading out of Salida up Monarch pass is a bit of a haul as the passing lanes are less frequent. Still, it's manageable as the amount of traffic drops off. Over the pass, it is pretty bendy and the passing lanes increase as you approach the stretch into Gunnison. It flattens out though nicely about 15 miles before you reach town.
I would have no hesitation about going that way. Another alternative is to head north from Poncha Springs to Buena Vista and then pick up 24 to the Springs. This can be crowded on weekends though.
2010 R-Pod 152
