Texman 182g Mods |
Post Reply | Page <1 1314151617 33> |
ZuBrew
podders Helping podders - pHp Joined: 11 Oct 2017 Location: Macedon, NY Online Status: Offline Posts: 113 |
Topic: Texman 182g Mods Posted: 11 Feb 2018 at 7:53pm |
Nice job on the mods. Where did you get the bug screens?
2017 Chevy Silverado 1500 4X4
2018 R-Pod 189 2013 Yamaha FJR 1300A |
texman
Senior Member Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Posted: 11 Feb 2018 at 8:25pm |
Amazon. I can send the link if you need it. Easy to install too and still wotking good.
texman
Posted: 12 Feb 2018 at 10:08am |
voisj
I wanted to mount my battery cuttoff like yours, but didnt have the tools to make a hole that big and not sure what to use anyway. the steel box i have is very hard to cut. What did you use to make the hole? |
texman
Posted: 12 Feb 2018 at 10:22am |
This is what i came up with to remount the battery box after having to move it because of the WDH. no room to spare. I think i got really lucky that this actually worked out. I remember looking at the others that have done this mod and didn't consider how tight all this is. The only problem is that i have to remove the tank cover to get to the latch for the battery box. Not a big deal since the only thing in there is batteries and no room for anything else anyway. I used 1.25" tubing and my nutsert tool to mount to the frame and then used 1/4" stainless bolts to mount it all up. I also had to reposition the safety brake by just turning it 90 deg to the inside, which isn't ideal, but should still work in case it ever happens. Now i am ready to try the e2 on a trip this weekend i hope. |
texman
Posted: 12 Feb 2018 at 10:24am |
a few more pics I managed to get the battery boxes inside the box, just no lids. i used a 2.6 cu ft box and i think that most are 2.75cf. If you want to use the box for storage, get the bigger box for sure. I actually found a use for the worthless sewer hose holder-floormat storage.
s |
texman
Posted: 12 Feb 2018 at 10:33am |
brake controller installed. Looks nice i think.
voisj
Senior Member Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 12 Feb 2018 at 11:18pm |
Texman, I used a regular hole saw going slow with oil, took awhile but worked. You could drill a small 3/8" hole and then use a jigsaw because the hole doesn't need to be perfect Since the square plate on the switch covers the holes edges. I put a good bead of silicone on the back of the plate before I screwed it on. |
texman
Posted: 28 Feb 2018 at 1:24pm |
Went ahead and replaced the tires to D rated Carlisle
And mounted the battery disconnect and added another Zamp port or 12v outlet |
texman
Posted: 01 Mar 2018 at 10:42am |
added the 3500# jack. Wish all mods were that easy and beneficial. it is a stromberg-carlson from etrailer.
i think i have maxed the available room on the a frame. propane cover is very tight. trying to figure out if one post is enough for the table mod and if i want to mount to the floor or mount to plywood base instead. |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6285 |
Posted: 01 Mar 2018 at 10:47am |
I am opting for two posts since I will be reusing the existing table top. Since it is rectangular, I am opting for more support so it won't wobble and spill things. I plan on putting the floor mounts directly on the floor. If I think it isn't sturdy enough, then I will use anchors to attach to the floor.
My order is projected to arrive tomorrow. |
