  New Posts New Posts RSS Feed: R Pod Model RP-179 Departure Checklist
Topic ClosedR Pod Model RP-179 Departure Checklist
PodWa View Drop Down
Direct Link To This Post Topic: R Pod Model RP-179 Departure Checklist
    Posted: 05 Dec 2016 at 11:10pm
We were only able to use our new RP-179 twice before having to prepare for winter.  I never owned or operated a travel trailer before, so I thought it might be wise to develop checklists for departure and arrival.  So far, I only have the departure checklist completed.  I am posting the departure checklist here in the hope that you more experienced RVers might take a look and tell me if I missed any items.  Feel free to copy my ideas and adapt them to your own R Pod if you desire.  Here is the checklist:
R Pod Model RP-179
Departure Checklist
1.  Propane Supply Valve – As Required
2.  Water Heater Electric Switch – Off
3.  Black Water – Discharged (As Required)
4.  Black Water Tank – Flushed (As Required)
5.  Grey Water – Discharged (As Required)
6.  Sewer Conduit – Drained and Stowed
7.  Potable Water Level – As Required
8.  Television Cable – Disconnected and Stowed
9.  Water Line – Disconnected and Stowed
10.  External Shower Compartment – Closed and Locked
11.  Windows – Closed and Latched
12.  Television – Stowed and Secured
13.  Table – Stowed and Secured
14.  Fan Vent Cover – Closed
15.  Slide Out – Retracted
16.  Refrigerator – Battery or Propane (As Required)
17.  Entry Door – Closed and Locked
18.  Hand Hold – Stowed
19.  Stairs – Stowed
20.  Electrical Power Cable – Disconnected and Stowed
21.  Stabilizer Jacks (4) – Retracted
22.  Trailer – Hitched and WDH Assembly Checked
23.  Safety Chains, Emergency Brake Cable, Electrical Pigtail – Connected
24.  Exterior Lights – Checked
25.  Chocks – Removed and Stowed
26.  External Storage Door – Latched and Locked
27.  Trailer Brake Controller – Green LED On When Brakes Applied
M&M View Drop Down
Direct Link To This Post Posted: 06 Dec 2016 at 7:38am
Good Morning PodWa, We're newbies too. We only had our 179 out 4 times this year (we picked her up in August) I've been meaning to put a list like this together. Thank you very much! Can't wait until Spring! Happy, Safe Travels.
2017 179 "Big Sexy"
2012 Honda Pilot
Direct Link To This Post Posted: 06 Dec 2016 at 11:32am
The list looks pretty complete. On Item 27, the lights will depend on the particular controller. On my Hopkins InSIGHT Flex Mount controller, a red dot is present when the pigtail (item 23) is plugged in. Numbers representing the amount of brake force applied appear when the brake pedal is pressed.
For item 16 (refrigerator), I recommend putting the refrigerator on propane while towing. It draws so much power on battery that you risk arriving to your destination with a battery insufficiently charged. The cause is that the wire supplying power from the vehicle to the trailer is usually too small to carry sufficient current to both charge the battery and run the refrigerator. You can search the forum for other post threads discussing this issue.
Welcome to the forum and to R-Pod 179 ownership. We are really enjoying ours since purchasing it last year. We have had long and short trips with it. We have another long trip coming up soon, which will be the first time traveling dry (no water in the fresh water tank). That should be interesting. I've also made a number of modifications to our 179 which have been very useful. Some of them may be of use to you also.
Direct Link To This Post Posted: 06 Dec 2016 at 11:33pm
You will have to adapt Item 27 to your brake controller.  I appreciate the hint on operating the refrigerator on propane while traveling.  How much propane does the refrigerator consume when operating in that mode?
Direct Link To This Post Posted: 07 Dec 2016 at 12:21am
The refrigerator does not consume much propane. The furnace, stove, and water heater are the biggest users of propane. You could run the refrigerator for weeks on a tank of propane if none of the above items were being used. If you take the outside cover off and look, you can see how little the flame is when it is operating.
birderdiane526 View Drop Down
Direct Link To This Post Posted: 07 Dec 2016 at 1:41am
Thanks PodWa for your list! One item for us is to check the ground under the trailer before pulling out to ensure nothing is left behind. A seemingly no-brainer until you leave something behind! (Speaking from experience!!)
Diane and Michael
2007 Toyota Tundra
BLOG:Podding in Paradise,
birderdiane526.blogspot.com
Direct Link To This Post Posted: 07 Dec 2016 at 10:18pm
Great idea!  I will add an "area clear" step to my checklist.
TheBum View Drop Down
Direct Link To This Post Posted: 08 Dec 2016 at 10:58am
Make sure nothing can get behind the panel below the fridge. You might want a setup checklist that includes checking there for objects before extending the slide.
Blue Highways View Drop Down
Direct Link To This Post Posted: 08 Dec 2016 at 11:30am
Good point, Bum! While towing, we had a kitchen drainer rack tumble from the counter into that very cavity once. When I began to extend the 179's slide, the kitchen drainer started pushing apart the panel mounted below the fridge. Took me a few more seconds to figure out the heck what was going on. Some damage occured.
I had to fix and remount this dummy panel with stronger screw connections. For this accident, I was glad for once that the factory had not mounted this panel with very strong screw-bites, and the far right side screw was misaligned, missing its grab entirely. So FR's haste actually lessened the damage.
Now, before extending the slide each time, I get down on my knees with a pocket LED to retrieve any stowaway objects behind there. It's become a routine. This is a "must-add" warning item for owners of the 179 floorplan, at least. Thank you for mentioning this, B!
IdSummitGirl View Drop Down
Direct Link To This Post Posted: 02 Apr 2017 at 1:55pm
Hi PodWa!
Love your departure checklist.
I image an arrival checklist might include the reverse of a lot of these items, but i wondered it you had a chance to get your thoughts together on this one?
Newbie looking to learn from others,
Thanks!
The Journey Matters....
