  New Posts New Posts RSS Feed: Tires
Topic ClosedTires
snorris View Drop Down
Direct Link To This Post Topic: Tires
    Posted: 28 Nov 2016 at 6:54pm
How good are the RPod tires? and what brand are they. I am thinking of buying the rpod and seeing's how it is a single axel trl I want the best tires on it. Will be pulling it down dirt and gravel roads etc. Thank You.
Bama Pod View Drop Down
Direct Link To This Post Posted: 28 Nov 2016 at 7:13pm
The HRE may be better for dirt and gravel roads. I forget what stock tires came on our new 180 but it is probably a safe bet they are not the best on the planet. Will likely replace when bearings need repacking assuming they last even that long.
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
Direct Link To This Post Posted: 28 Nov 2016 at 7:47pm
The tires we had on our 2010 171 lasted the 5+ years that we owned the 171, we had over 15 thousand miles on it when we traded it in for our 179. We had them inspected each year by our mechanic when he did the trailer inspection. Present tires have over 8 thousand miles on them and are still looking good.
Direct Link To This Post Posted: 28 Nov 2016 at 7:55pm
Wow. That's encouraging.
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
TheBum View Drop Down
Direct Link To This Post Posted: 29 Nov 2016 at 11:25am
The factory tires aren't great and if you get one of the larger Pods, they are barely adequate weight-rating wise. They're also a little low on the speed rating.
If you want good tires, look at ones that have a D weight rating. Most also will handle higher speeds. We put Carlisle Radial Trail HD tires on our 179 after blowing out both factory tires on one long trip and couldn't be happier.
Direct Link To This Post Posted: 29 Nov 2016 at 3:19pm
+1 on Carlisle tires. I have one complete season on mine, with no issues. I think those that upgrade to "D load" tires are wise persons.
mcarter View Drop Down
Direct Link To This Post Posted: 29 Nov 2016 at 5:03pm
My 2015 178 came with Grand Ride 205/75R14s, C rated.  I honestly had no problem with them.  BUT I didn't like the sidewall flex and went to Carlisle tires due to fact I could get them in a D rate.  I feel safer.
Direct Link To This Post Posted: 29 Nov 2016 at 7:36pm
Will have to check them out, we are all for safety!
sailor323 View Drop Down
Direct Link To This Post Posted: 29 Nov 2016 at 8:19pm
I don't know.  We put many thousands of miles on the factory tires with no problems.  We replaced them due to issues that had nothing to do with the tires themselves
Direct Link To This Post Posted: 29 Nov 2016 at 8:43pm
Thanks for all the info. Really appreciate it.
