![]() Posted: 21 Nov 2016 at 3:04pm |
Neither magnesium nor aluminum are recommended for the ice pick. High strength carbon steel is preferred, but rust can be a problem. Check it each year. ![]() |
osage ![]() Senior Member ![]() Joined: 13 Mar 2016 Online Status: Offline Posts: 146 |
replaced the rod this spring it is about 1/2 gone will replace it this spring. water here is hard if you want a drink takes a hammer and ice pick to get one then you chew it
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6429 |
I believe that Suburban recommends using the Magnesium anode rod unless one is in a place with very corrosive water. In that case, Suburban says to use the Aluminum anode rod. One does run the risk that the aluminum anode rod will not provide adequate protection. However, if the magnesium one is corroded away, you end up with no protection.
As I understand, aluminum is less reactive than magnesium. Less reactive means longer life but lesser protection. Aluminum would last longer in corrosive water conditions, but would offer less protection in less corrosive water. If changing the rod doesn't bother you I would use magnesium. Just keep an eye on it every couple of years until you get a calibration on its life span.
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1454 |
Either is fine. I forget the difference. I think one is better for hard water. But if you find one that fits you're good.
TT |
FJ Cruiser |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3346 |
That is a good question. Whatever came as standard equipment on my 2011 model 177 is the same anode I continue to use. Still is great condition.
what anode rod does everyone use? aluminum or magnesium ?
