Periodic dumping with R-dome? |
Post Reply | Page <1 345 |
Podster
Topic: Periodic dumping with R-dome? Posted: 04 Nov 2016 at 4:36pm |
Totally Totes on this one! |
Cliff & Raelynn
Posted: 04 Nov 2016 at 4:15pm |
You "fill the grey" in 3 days without showering?? I can't for a moment imagine how you manage that. But.. whatever. Everyone's camping style is different. It shouldn't take 30 minutes to put up a dome. I did it this spring, on camera, no hurry, solo, 9 minutes. Tearing down and stowing, just to move the camper and back would certainly be a pain. Shower pan filling up isn't a crisis, just an indicator that your tank is full. Again, you say you can only go 3 days.. but your tank isn't full.. you are choosing to only go 3 days. We only carry a tote if we are going out for more than 5 days, with no facilities. Happens a couple/few times a year. We carry the tote in the truck. A small one could be carried on the tongue I guess. |
CharlieM
Posted: 04 Nov 2016 at 3:10pm |
As I recall the 15 gallon Barker Manufacturing Tote-Along traveled well just above the battery, behind the dual propane tanks, strapped on with Bungee cords. The 22 gallon model is only slightly wider and might also fit.
http://barkermfg.com/original.html |
rkleim
podders Helping podders - pHp Joined: 10 Jun 2016 Location: Tampa, FL Online Status: Offline Posts: 15 |
Posted: 04 Nov 2016 at 8:46am |
Well, it's 2 of us and we have never taken a shower in it. Generally, it is quite hot, sticky, and buggy out, and the assembly takes about 30 minutes (pounding stakes in can be slow). I don't know where to carry an external tank. Moving the Rpod usually also involves putting everything breakable inside away, raising all stabilizers, hitching up, etc.... Probably an hour from start to finish. Sensors? I know how bad they are, but the better ones are close to $200! No, we have not gone until the shower shows water, but I hate to wait for a crisis. I was hoping there was something else people did ? Move with the Rdome attached?
Where do you carry your external tank?
Richard 2015 Jeep Cherokee Trailhawk with Factory Tow 2016 FR R-Pod 179 |
Happy Tripping
Posted: 04 Nov 2016 at 8:04am |
I don't see the problem.
With a 171, by myself, it takes me less than 10 minutes, start to finish, to completely take our r-dome down, a little more to put it up. Of course, some of the other models may be more time consuming. I haven't tried it, but I bet by leaving it at the camping site assembled but simply slid out of the rail and weighed down, it would go back up really fast. Relax and enjoy the experience, what's a measly few minutes every 3 days when you are out enjoying camping? |
Posted: 04 Nov 2016 at 7:58am |
If you are dumping every three days.. well.. that's a lot of grey water. We generally can go a week if trying, both showering every day. Our "problem" will be topping off the FW tank.
Also, are you "full", or is the gauge panel "indicating full"? The gauges are useless. Many will show full long before they are, some will even with an empty tank. We are full when the shower backs up.. There is no shame in using a tote, and it's the correct answer for your issue, in my opinion. |
Posted: 04 Nov 2016 at 1:32am |
Compromise. Use less water so that tanks don't need to be dumped that often. Use campground facilities as much as possible. Don't take a shower every day. Or get one of those rolling dump tanks.
The grey tank usually fills quicker than the black. Some people will move grey water to the black tank to take full advantage of both tanks before dumping. You can get pretty close to 2 potable tanks worth of water into both the grey and black tanks that way. If there's really no choice but to hook up the pod and take it to a dump station, that would play into my decision whether or not to set up the r-dome. I don't take a portable dump tank with me everywhere, but I do have one that I use when I want to use the dome and I want to stay in one place for a week or more. We can go a good 5 days without needing to dump though, and even then it's the potable water that runs out first. TT |
FJ Cruiser |
rkleim
Posted: 03 Nov 2016 at 10:54pm |
We really like our Rdome, but by the time it's all set up and staked down and the mosquito net thing is attached and all, we don't really want to undo everything every 3 days or so just to go dump the grey water (we generally use state parks). is there some solution I haven't thought of? what do you do?
Thanks
