  New Posts New Posts RSS Feed: R-Pod TV Antenna
Topic ClosedR-Pod TV Antenna
TerryM View Drop Down
Direct Link To This Post Topic: R-Pod TV Antenna
    Posted: 01 Jan 2010 at 5:02pm
Originally posted by David and Danette
 The button was pressed and light was on. At Koreshan State Park we also had better reception with the rabbit ears. Were ready for something better. It it is helpful at home if you turn the the switch off we lose the picture so it does work just not that well if your a distance from the television broadcast signal. The rabbit ears are good but not conveinient.    David
As you know it is pretty flat here in Florida.  So signals should be able to get from Jacksonville to Saint Augustine with no trouble at all.  After all it's only about 30 miles from my house.  I can't get anything at all.  One place I was camped I got 3 channels so I know it is working.  Eventually I'll get the antenna I mentioned in the first post.
Terry
Direct Link To This Post Posted: 06 Jan 2010 at 9:46am
     I contacted solidsignal and was told that the Winegard antenna the RPod has now would be about as good as I could get for reception. I asked about the Sensar III  and was told it would be a down grade and the Antennacraft ministate would not give any better reception. So I will see If I can change the connections. I have added two splitters I will try to elimanate them.   David
2014 Ram 1500 Quad cab
pjanits View Drop Down
Direct Link To This Post Posted: 15 Sep 2015 at 8:28pm
We carry old movie DVD's for those emergency times.
Also as a retired Motorola Radio Engineer, I can say Digital TV sucks. Analog worked fine for distance and storms because you would just see some interference and static on the audio.
Digital loses ALL the signal under these circumstances. Also due to the frequencies used (line of sight only) you will loose signal from trees. Yes Trees. They can eat the signals and diminish them before your camper sees them. Trust me  pine needles are the exact length of the antenna of some digital frequencies.  We ran into those problems with Police Radio in the Northern parts of the US.
We have pretty much given up on digital TV unless near a urban area. And then it's religion or cartoons or Spanish TV. Rarely ever see the news or weather when we want to.
Pete
N9SWH
jstrenn View Drop Down
Direct Link To This Post Posted: 15 Sep 2015 at 9:25pm
pjanits, you do realize this thread is 5 or 6 years old right?
Direct Link To This Post Posted: 16 Sep 2015 at 8:30am
No I didn't, but the information is still up to date.
Camper Bob View Drop Down
Direct Link To This Post Posted: 16 Sep 2015 at 10:21am
Not only do we not watch TV while camping, we specifically ordered our Pod without one.  If there is a cable connection, we hookup and have an adapter that plugs into a USB port on the laptop to watch the news. Other than that, we camp outside in the wonderful wilderness that we have dragged our Pod to see.  Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Direct Link To This Post Posted: 16 Sep 2015 at 7:48pm
No worries on reviving old threads, we like to recycle electrons around here.
jarpod View Drop Down
Direct Link To This Post Posted: 16 Sep 2015 at 8:54pm
i had the same problem with our antenna on our 2010 175. i went to Walmart and bought a leaf ultimate antenna and have great reception now before the channels faded or could not pick up any at all. and i can move the antenna around if need to
dropkick View Drop Down
Direct Link To This Post Posted: 16 Sep 2015 at 9:48pm
So has anyone actually REMOVED this aerodynamic dragging 70's eyesore?  How big are the holes?  Easy to seal?  Did you have to put a plate or something over it?  That is prime solar panel real estate up there....
I don't even know if the audiovox "TV" (I use that term loosely) the pod came with will even tune a digital signal. Nothing on network TV anyhow. Just plug into cable or dvd, or suprise---open the windows and look out and then take a walk :)
Direct Link To This Post Posted: 16 Sep 2015 at 10:11pm
We used the antenna on our 179 down at the KOA in Enfield,NC and got 32 channels. all the channels came in really nice.
