Page 12> |
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
![]() Posted: 24 Sep 2016 at 3:34pm |
Now that the new, almost available, rpod models have a traditional awning option,( I've only seen pictures) and the Winnebago and jayco clones also have them, Has anyone looked into or put an awning on their pod? I've been looking and found a few that may work, Forest River will give me no info and dealers have no clue.
This doesn't seem like rocket science. Anyone done this? |
It's possible with the correct length of awning, but the curved factory keder rail would have to be replaced with a straight one.
I'm researching it myself. I checked the Thule website and found a few that should work, but I can't find any US retailers that carry their RV awnings. |
Saw this on EBAY ,
http://www.ebay.com/itm/111797636467?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT They claim they can cut it down for a fee with shorter arms. making a bracket to mount it to shouldn't be to hard to make, ( I weld alot), and the stock RV channels are available if need be. This seems simple enough, Iv'e sent in the measurements to them and am waiting for a response. the arms can only be 61" tall, and to mount it to my pod (180) I need 8'6" arm mounting point to arm mounting point to mount to the aluminum pod frame. Just a simple crank unit but it should do the job.
We have the Carefree slideout cover on our 179 and couldn't be happier. I'm sure their awnings are of good quality.
Did you buy the slideout cover or did it come with the trailer? I'm also looking to install a slideout cover also.
Bought it and installed it ourselves. The toughest part was feeding the fabric into the keder rail, especially with the drainage spouts in the way. Spreading the mouth of the rail open a bit really helped, but it was a two-person job on the 179. Since the 180's slide is narrower, a single person may be able to install it, although it helps to have one person support the roll and the other to feed the fabric into the rail.
Bum,
Where did you get it and what brand?. I think this is a must have and I'm a little scared to order one hoping i got it right.
Rgds John |
The brand is Carefree of Colorado, the same as the awning you were looking at. The model we bought is the Slideout Cover. We bought it from RV Parts Country.
You'll have to do some measurements to get the right length, but the instructions on the Carefree website are pretty good (click on "Learn More..." in the Awning Length section). |
OK, so I'm looking at the Carefree Pioneer Lite awning and it seems to be a good bang for the buck. What's the longest awning that could be used on a 179, being mounted high enough so that the door clears when the awning is open?
I did some measurements last night. It appears that a 9' awning would barely fit, 8' to be safe; with a 9' awning the outdoor outlets become an obstacle. The keder rail would have to be cut off and straightened to get coverage over the door. So, it's definitely not something I'll attempt until the warranty is up.
Page 12> |
