  New Posts New Posts RSS Feed: screw size and thread
Topic Closedscrew size and thread - Event Date: 10 Aug 2016
Giacomo View Drop Down
Direct Link To This Post Calendar Event: screw size and thread
    Posted: 10 Aug 2016 at 7:39pm
Need to know best screw thread and size for use in attaching items to the interior walls given the fact that
 they are only 1/8 inch thick. Any one?
JandL View Drop Down
Direct Link To This Post Posted: 11 Aug 2016 at 9:51am
If whatever you are screwing to the wall is very light you can use a #6 or #8 wood or sheet metal screw. It doesn’t take much force to pull a screw out of an 1/8” wall so for heavy items you need Hollow Wall Anchor for wall thickness 1/8” – 1/4'’ .
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
sailor323 View Drop Down
Direct Link To This Post Posted: 15 Aug 2016 at 7:22am
I have used #8 screws and had no problems.  I've hung spice racks and other moderately heavy objects with them.  If you want more holding power, use them in conjunction with double sided tape or use hollow wall anchors as JandL suggested
john in idaho View Drop Down
Direct Link To This Post Posted: 15 Aug 2016 at 2:02pm
And remember - don't push very hard on the drill -one wouldn't want to poke a hole thru to the outside.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 15 Aug 2016 at 6:58pm
 I used a couple of small wall anchors for hanging a full length mirror on the outside of the bathroom door (it is hollow).
 I would use several wood screws and epoxy (if it's to be permanent) to mount a piece of hardwood to an outside wall, then attach what you need to it.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
