  New Posts New Posts RSS Feed: 2016 177 Hot Water Heater Bypass Valve
Topic Closed2016 177 Hot Water Heater Bypass Valve
Direct Link To This Post Topic: 2016 177 Hot Water Heater Bypass Valve
    Posted: 07 Aug 2016 at 7:50pm
That is the anti freeze take up hose, and it's in the wrong position for using the fresh water holding tank, I think. If the line it points to goes nowhere, it's wrong. The WH valves are the other 3, and they are set properly for use.
TheLoneRanger View Drop Down
Direct Link To This Post Posted: 07 Aug 2016 at 7:08pm
Is the WH bypass valve in this picture set to the correct position for "summertime" or should it be parallel with the blue hose segment?
Thanks for your help!
