List Your Mods:
 Post Reply Post Reply Page  <1 6869707172 77>
ReddOrion View Drop Down
Post Options Post Options   Quote ReddOrion Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 22 Jan 2013 at 4:03pm
For our 2013 RPOD 177, we have done the following:
  • New thicker access door to the storage under dinette seating
  • LED bulbs throughout, inside and out
  • Moved dinette table closer to wall and moved seating pegs towards wall
  • Replaced TV antenna outputs with 12v outlet in entertainment cabinet over the bed
That last mod wasn't difficult. There was a 12v circuit there feeding the antenna jack that I was able to reuse once the jack was 100% removed. Soldered a few things, changed the fuse size and it was good to go! Also added removable grommets for the raw holes that FR left for us Ying Yang Finished pic below.
For the Springtime before we take it on it's maiden voyage, we are doing the following:
  • More 12v outlets behind power supply box on side of dinette seating
  • 2 blinds in bed area will be changed out for dual rod opaque curtains
  • Oxygenics shower head
  • 60" sewer hose carrier
Minor stuff, but it should fit our camp style. We got a good deal at our local fabric store for the curtain material, looking forward to getting those done. We'll even have two spare blinds for when the front ones peter out!
Jason & Kim
2013 RP-177 HRE
2005 Tahoe LT
danthoman View Drop Down
Post Options Post Options   Quote danthoman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2012 at 5:59pm
The wine glasses are ready the bottle is open see you in a little while.
Linda and Dan
Calley the golden retriever
R-pod 177 and a Tundra 8 cyl
dsmiths View Drop Down
Post Options Post Options   Quote dsmiths Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2012 at 8:22pm
Dan, I like that wine rack, looks better than factory, I'll have another Merlot thank you very much.
Dane and Donna Smith
2011 RP-172
lift kit
Post Options Post Options   Quote danthoman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2012 at 5:46pm
Here are a couple more mods I've made.  The first is the wine rack on the right side of the fridge.  The second was to remove the bench seat on the right and build one along the back to form an 'L'.  My wife is going to make new cushions.  It's amazingly comfortable.  I never could read or use the computer the way it was.  There just wasn't enough room to get comfortable.
Wine rack
Bench seat
I need to thank the guy on the 'other forum' who did something similar.  My wife was against the mod till she saw the photos.
Linda and Dan
Paige View Drop Down
Post Options Post Options   Quote Paige Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2012 at 3:46pm
   We bring a small flat screen TV with us as the one that came with the RPod is too small and in a poor location. We bought a coaxial cable connector from our RV dealer and drilled the hole toward the front of the Pod. We screwed it in and sealed around the edges.
   We then put an interior one on the dinette bench and connected them with a cable. (photos below) Now, when we want the TV there, we have a cable connection. The next job is to put another outlet in the dinette bench area.
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Post Options Post Options   Quote Paige Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2012 at 3:40pm
Our septic storage tube took a beating in its original location. We made a bracket and connected it to the side of the tongue. We also ordered another tube from FR so if we need the extra length, we have it.
Paige and Pete
2010 177 - RPug
Post Options Post Options   Quote Paige Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2012 at 3:34pm
We are busy doing mods before we head south to Florida. My husband made this cabinet and screwed/glued it into place.
Paige and Pete
2010 177 - RPug
Post Options Post Options   Quote danthoman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 4:28pm
I've made a few mods, so far.  Nothing really new but here they are.
The first was to make a cutting board which fits over the stove and a paper towel holder.
The second was to remove the boards under the sink and add some vertical slats to hold pans.  There was a lot of wasted space in there.
And finally, I extended the length of the drawers by 4 inches.  My next project will be to change from 2 drawers to 3 drawers.  Almost forgot.  You can see the front of the slide out cabinet I made for under the bed.  I even remembered to leave enough room for the heater.
Post Options Post Options   Quote Paige Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 10:58pm
Had to modify it a couple of times by widening it as the curvature of the ceiling closed down the opening on the shelf. It allows us to get all the odds and ends off the table...books, cards, pencils, games, etc.
Paige and Pete
2010 177 - RPug
Post Options Post Options   Quote Paige Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 8:24pm
Adding a door in the side of the dinette bench for better access.  Cabinet will be divided into two storage units. The one with the door will hold our set up tools, like the drill for the scissor jacks.
Paige and Pete
2010 177 - RPug
