Battery Not Charging |
Post Reply | Page 12> |
CharlieM
Topic: Battery Not Charging Posted: 08 Dec 2016 at 7:55pm |
The converter should put out 13.2-14.4 volts. You don't say but I'm assuming the 12.5V is measured at the battery with the converter plugged in. If true my guess is the reverse polarity fuses in the converter are blown. The converter has two high current fuses to protect the converter from a reversed battery. They will blow if the battery is ever connect backwards even for an instant. You can test the fuses with an ohmmeter or by disconnecting the battery and plugging in the converter. With the battery disconnected a working converter should power the lights and fan. If not, and all the circuit breakers are on, it's probably the reverse polarity fuses. A fully charged battery should read 12.6+ volts with no load.
Posted: 08 Dec 2016 at 7:42pm |
If the converter is on, you should be seeing 13.5V or so.. If not, the battery could be bad.
The most basic battery test is to charge it fully, disconnect it, let it sit at least 6 hours, then measure it's voltage with a multmeter. |
MDPaddlersPod
Senior Member Joined: 06 Jul 2016 Location: Maryland Online Status: Offline Posts: 135 |
Posted: 08 Dec 2016 at 4:33pm |
Can anyone tell me what voltage the converter is supposed to charge to? On shore power overnight I am getting a battery voltage reading of about 12.5. The battery is less than a year old.
MDPaddlersPod
2017 RPod 179 2002 Silverado1500 |
Posted: 03 Nov 2016 at 9:33am |
It's "supposed to be" a direct fit. It isn't what used, but is the same "guts". I had to remove the back of the WFCO box to fit mine, but it was bought for another camper and would have been stand alone in it..
NoDak
Newbie Joined: 11 Aug 2016 Online Status: Offline Posts: 26 |
Posted: 02 Nov 2016 at 8:42pm |
Is that a direct fit replacement, or is some surgery needed?
Posted: 02 Nov 2016 at 1:36pm |
Kantuckid
Newbie Joined: 14 May 2016 Location: KY Online Status: Offline Posts: 38 |
Posted: 02 Nov 2016 at 1:06pm |
I called WFCO tech line. Guy said to disconnect the battery then turn on all/most dc loads in camper, while also connected to shore power, then check for dc output from convertor to the battery both at the convertor, with panel cover removed and at the battery itself. Also possible is a dead cell in my battery which I doubt as my charger is designed to detect such issues. The convertor runs in parallel with the battery and puts out enough dc volts to charge the battery while in camper's in use.
Fingers are crossed to avoid buying a new convertor. The warranties are only to the original owner. I just checked the battery with a load tester and it seems OK but still could have a cell that vibrates apart? The pods convertor does what it's supposed to do at the panel and at the battery connection. battery is an Exide deep cell one year old. It's possible that my battery was so discharged that it "made me think" I had another issue or- the dead cell thing...? |
Kantuckid
Posted: 02 Nov 2016 at 12:38pm |
My battery already has a cut-off. My battery charges to full charge level via external charger with no load. The problem seems to be the power convertor. Mine has model WF-8955 PEC.
A dealer tells me the lower circuit board is what usually blows. I had a bad one on my last RV. I suspect that connecting to shore power w/o a switch off, then back on after connection leads to these problems. Not that I know this for a fact. |
Posted: 01 Nov 2016 at 1:47pm |
+1. This answer is better than mine.
I installed a battery cut-off switch. You can see it in my mods. |
CharlieM
Posted: 01 Nov 2016 at 11:16am |
Your converter and battery may both be fine. The propane detector draws a constant ~0.16A and the wall thermostat adds some. In two weeks this adds up to (0.16x24x14) ~54AH. The standard dealer supplied Gp 24 battery is rated at 86AH so you're down 63% before you leave. The solution to this is either leave the Pod plugged in or disconnect the battery.
