Heat thermostat digital replacement |
Pod People
Topic: Heat thermostat digital replacement Posted: 19 May 2016 at 7:34pm |
I want to replace my original thermostat with a digital unit. I have an older Pod-a 2009 173 model that uses the thermostat to control only the heat. The AC is controlled directly on the front panel of the unit.
I did a search and found no posts related to my situation. I have done a little research and found that the thermostats should have battery backup and be 12volt compatible. I don't necessarily need for them them to be programmable. I found this website from a Google search. They have lots lots of different heat only thermostats. http://www.supplyhouse.com/Thermostats-327000 I have no idea which one would work. I will call them, but prefer to hear from other pod modders first. Has anyone done this or know much about these thermostats?? Any suggestions or recommendations ? Thanks Vann |
johnmaci
Senior Member Joined: 17 Jun 2014 Location: MD Online Status: Offline Posts: 202 |
Posted: 19 May 2016 at 7:48pm |
I recently installed this model and works well:
http://www.amazon.com/Honeywell-TH1100DV1000-Pro-Digital-2-Wire-Heat/dp/B00H6ARNXO?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_search_detailpage |
CharlieM
Posted: 19 May 2016 at 8:32pm |
Try this. Easy to install and works great.
http://www.amazon.com/LuxPRO-PSD010BF-Heating-Digital-Thermostat/dp/B005FYNCJW/ref=sr_1_1?ie=UTF8&qid=1463704291&sr=8-1&keywords=luxpro+psd010bf |
