  New Posts New Posts RSS Feed: 12 volt TV questions
Topic Closed12 volt TV questions
Unclewillis View Drop Down
Direct Link To This Post Topic: 12 volt TV questions
    Posted: 03 Jan 2016 at 6:04pm
So I've been following these threads about using an inverter or getting a 12v tv. If I were to get a 12v tv, would it have the same capabilities as the factory TV I have in there now. Where would it get power? other than an inverter?
Daddy, Mommy and Daughter.
Rpod 176T 2015
Nick:
ouR-pod
Direct Link To This Post Posted: 03 Jan 2016 at 6:12pm
It would get power from the 12v system. You may or may not need to add a 12v outlet near the tv mount.
I don't understand the "capabilities" question.. it's a tv.
This is only "an issue" if you intend to camp off grid or boondock without 120v..
Direct Link To This Post Posted: 03 Jan 2016 at 6:19pm
yes, we camp off grid a lot with solar.
By capabilities, I mean will the TV do everything a AC do? will it be HD, Will it have stereo outputs for sound? same channel scan? just stuff like that.
Rpod 176T 2015
Nick:
ouR-pod
Direct Link To This Post Posted: 03 Jan 2016 at 8:25pm
Yes. The power source is just that. The truth is, most tvs are low voltage to begin with.
Direct Link To This Post Posted: 03 Jan 2016 at 8:34pm
thank you very much
Rpod 176T 2015
Nick:
ouR-pod
Podster View Drop Down
Direct Link To This Post Posted: 04 Jan 2016 at 5:53am
Another possible option, since camp of the grid a lot, is using a portable DVD player. If you are out in the middle of no-wheres-ville you probably don't get many over the air (OTA) channels anyway. So, consider the use of a self contained portable DVD player that is powered by rechargeable batteries. Before we got the POD we tent camped and used one in the evening and charged it during the day in our tow vehicle while we were out on excursions... worked good.
Cliff & Raelynn
Ranger 4.0/178
Akula1 View Drop Down
Direct Link To This Post Posted: 04 Jan 2016 at 8:51am
Your best bet is to save your money, and get a 100W Inverter, and a multi plug adapter for it, that way you can plug both of them in and run it off your battery. The only thing you may need to do is put in a 12V outlet by the TV. They both run less than 100W, and it is the most economical way to do it.
2019 R-Pod 190
2019 Colorado LT
CharlieM View Drop Down
Direct Link To This Post Posted: 04 Jan 2016 at 9:08am
Your options depend on your goals. If you already have a TV and are satisfied with it, but it only runs on 120VAC, you cheapest option is a 150-300 watt pure sine wave inverter. However, this is also the least efficient from a power standpoint. Efficiency is important if you spend time off the grid because it affects battery life. If you value efficiency or are otherwise less than satisfied with your existing TV your best option is a 12VDC TV. A direct 12V TV
eliminates the losses incurred with a DC-to-AC-to-DC power conversion.
Majestic Global makes a nice, though pricey, line. These TVs have all the bells and whistles, inputs, DVD player, headphone jack, remote, etc.
