  New Posts New Posts RSS Feed: Isolate water heater
Topic ClosedIsolate water heater
Paulipod View Drop Down
Direct Link To This Post Topic: Isolate water heater
    Posted: 04 Oct 2015 at 1:21pm
I have winterized our Pod without antifreeze but want to use a few more times. I want to use the system with cold water only and isolate the hot water heater. If I use the bypass valves to cutoff heater(I know not to turn on)are the by pass valves strong enough for system pressure to use the cold side only by turning off cold in and hot out on the heater and opening the bypass valve?
2012 Rpod 176 HRE
2005 Trailblazer EXT
2004 2007 Daughters
Ageless Wife
oh and a awesome dog
HuronSailor View Drop Down
Direct Link To This Post Posted: 04 Oct 2015 at 3:50pm
Yes, you should be fine.
Direct Link To This Post Posted: 04 Oct 2015 at 6:12pm
Yes, you will have no problems.
