  New Posts New Posts RSS Feed: RP172 lower bunk mod?
Topic ClosedRP172 lower bunk mod?
jclaffee View Drop Down
Direct Link To This Post Topic: RP172 lower bunk mod?
    Posted: 01 Sep 2015 at 7:53pm
I decided to add some struts to help lift the lower bunk platform.  The install went ok, but the 3/8" plywood deck was in pretty tough shape, and the hinges were installed pretty poorly at the factory - all askew and really close to the edge of the plywood.  After a month of use the hinges just ripped out of the plywood.  (yes, the struts i used are probably overkill, but that horse has left the stable).
No problem!  I went and got some 5/8" material so i could replace the bed deck and the 10" strip of plywood at the leading edge of the bunk.  I also got a 72" piano hinge to make sure the sucker worked.
Got everything cut, and went to pull the old 3/8" pieces out...and the big piece doesn't fit.  I can't get the darn thing out Wink.
Has anyone done this?  Do I really need to remove the top bunk in order to get the bottom bunk deck out in one piece?  Obviously i could cut it, but that won't help me getting the new, thicker, heavier piece back in.
Webstas View Drop Down
Direct Link To This Post Posted: 04 Sep 2015 at 12:47pm
I was able to get the 3/8 piece out when i did that mod
Direct Link To This Post Posted: 04 Sep 2015 at 12:48pm
it was tricky and it barely fit back in, did you buy the kit from camping world?
this is what i got http://www.campingworld.com/shopping/item/standard-bedlift-kit/66717
