  New Posts New Posts RSS Feed: Bathroom exaust fan
Topic ClosedBathroom exaust fan
cdremy View Drop Down
Direct Link To This Post Topic: Bathroom exaust fan
    Posted: 17 May 2015 at 4:51pm
Has anyone had problems with there fan not working.Looking for some troubleshooting suggestions  if the  fuse replacement does not work.  Thanks
Direct Link To This Post Posted: 17 May 2015 at 5:08pm
If you have trouble with it after the fuse change, call them. Fantastic Fan has GREAT customer support.
CFWARREN View Drop Down
Direct Link To This Post Posted: 17 May 2015 at 5:09pm
Probably a dumb question, but you did open the vent, yes?
The fan won't run with the vent closed.
2016 179 - Hood River Edition
2008 Nissan Xterra
Podster View Drop Down
Direct Link To This Post Posted: 17 May 2015 at 5:16pm
...good point, could be related to that switch. I think the Fantastic Fan is guaranteed for life!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 17 May 2015 at 5:43pm
Yes we did have it up. Could be that the switch may not have activated. Thanks for your positive suggestions. I'll go and try it again tomorrow.
Direct Link To This Post Posted: 17 May 2015 at 9:11pm
Sometime the switch that depresses when you close the fan lid sticks and needs some grease.
Direct Link To This Post Posted: 27 May 2015 at 8:22pm
Where do you access the switch.
Direct Link To This Post Posted: 27 May 2015 at 8:33pm
You remove the screen and you will see it on one of the cross pieces it is a plunger type switch. Would be easier if you had a ladder and go from the top. We fixed ours while at Cape Hatteras so we had to go up through from inside. Greased it and it worked fine after that.
Direct Link To This Post Posted: 28 May 2015 at 1:03am
Thanks for yor reply.
Direct Link To This Post Posted: 28 May 2015 at 9:15am
It's a small little "post" kind of thing, feels kind of like a ball point pen clicker.. It should push down easy, and then pop back up.
